$175 Class D amp--120 wpc
0 Members and 6 Guests are viewing this topic. Read 1217176 times.
IronForge
Re: $175 Class D amp--120 wpc
« Reply #2480 on: 19 Apr 2011, 08:59 pm »
Has anyone done a 5.1 system using these amp modules?  What is the cheapest way to feed these amps home theater? (DTS/Dolby/etc)
What is gained by using the dodd audio preamp?  What type of input does the dodd audio preamp take?
srb
« Reply #2481 on: 19 Apr 2011, 09:12 pm »
Since you need a Dolby/DTS decoder, beyond a few rare stand-alone decoder units, you are basically talking about one with a preamp built-in, either a surround processor/preamp or a surround receiver with preamp outputs.  The cheapest solution would be probably be a surround receiver with preamp outputs (and having the latest codecs and features) or an older used surround preamp/processor that only does Dolby/DTS 5.1, and therefore has taken quite a hit on resale price in the used market.
The Dodd Tube Buffer is a two channel unit, and while it could be used on the main front L/R channels, you would not need it's impedance matching buffering ability with a preamp, and I imagine that any "tubiness" flavor that might be added to the two front channels would not be of too much use for HT.
IronForge
« Reply #2482 on: 19 Apr 2011, 11:41 pm »
Would it be possible, or laughable, to connect this up to your HTPC and have that do the decoding?  Heck, if you had a large enough metal PC case you could mount a small mATX board and the amp in the same case, and have a PC fan or two blow on it.
wushuliu
« Reply #2483 on: 20 Apr 2011, 12:04 am »
You may want to check out Pete Schumacher's PCeiver build...
http://techtalk.parts-express.com/showthread.php?t=218374&page=7
jtwrace
    • TIPP YouTube Channel
« Reply #2484 on: 20 Apr 2011, 12:08 am »
Sorry, I thought you were being facetious when I saw the the external wiring in the link you shared. I'll check out the rest of their wares. Thanks.
http://www.partsconnexion.com/wire_hookup_dhlabs.html
srb
« Reply #2485 on: 20 Apr 2011, 12:18 am »
I use an HTPC for encrypted cable HDTV recording, playback and DVD playback.  But I choose to use an external AVR for audio decoding and preamplification.  There don't seem to be too many high quality 5.1 analog audio soundcards, as opposed to high quality 2 channel analog audio soundcards.
If you want to keep additional heat and size down, a surround processor may be a better choice than a receiver if you don't plan to use any of the receiver's internal amplifier channels.
Again, if 5.1 Dolby/DTS is all you need, you may be able to find a surround processor known for better than mainstream receiver audio quality in an older used unit from manufacturers like Anthem, B&K, Rotel, etc. in the $300 - $500 range.
IronForge
« Reply #2486 on: 20 Apr 2011, 12:26 am »
Sweet, that's what I thinking about.  They have some HTPC cases that are very receiver-ish looking, too.
topp
« Reply #2487 on: 20 Apr 2011, 02:12 am »
Where are you guys buying your enclosures for your amps?  Any suggestions would be appreciated.
Topp
corndog71
  • Some people call me Rob.
« Reply #2488 on: 20 Apr 2011, 03:26 am »
Topp
Here's where I got mine.
http://cgi.ebay.com/3U-Audio-Steel-Aluminum-Rackmount-DIY-Case-10-19085B-/370238950878?pt=BI_Electrical_Equipment_Tools&hash=item5633f60dde
NeilT
« Reply #2489 on: 20 Apr 2011, 03:35 am »
Topp
I just bought an enclosure for my Dodd buffer from these guys.
http://www.circuitspecialists.com/level.itml/icOid/4158
TrungT hooked me up.
Neil
praedet
« Reply #2490 on: 20 Apr 2011, 01:08 pm »
see page 113 post 2247, I used 1Kohm vishay nude resistors, just cut the
wires down and soldered resistors to the end of the wires
Any idea where to get these resistors?  What power rating?  I have been searching and have found LOTS of choices...
jtsnead
« Reply #2491 on: 20 Apr 2011, 02:29 pm »
praedet
« Reply #2492 on: 20 Apr 2011, 02:43 pm »
What is the difference between 1K, 1K2, and 1K5?
johnhc
« Reply #2493 on: 20 Apr 2011, 03:33 pm »
jtsnead, 1K2=1,200 Ohm, 1K5=1,500 Ohm.  See here http://en.wikibooks.org/wiki/Practical_Electronics/Resistors  Enjoy, John.
corndog71
« Reply #2494 on: 21 Apr 2011, 10:38 pm »
SDS-258 Done!  Now I just have to remember to buy the little fuses and not the big ones.
Success!!!
jtwrace
« Reply #2495 on: 21 Apr 2011, 11:50 pm »
How does it sound?
corndog71
« Reply #2496 on: 22 Apr 2011, 12:32 am »
So far it sounds good.  I just had it driving a pair of AV123 X-LS bookshelf speakers.  Over the next few days I'll be pairing it with X-Omnis and X-Statiks.
I've done a couple of tweaks right off the bat.  I swapped out the PS caps for Panasonic 6800uF giving me 40,800uF total.  I also swapped out the stock bridge rectifier for a 25 amp version.  I've read many times over the years that you can't go too big on the power supply so I got an Antek 1000VA / 45V transformer.  This whole thing has to weigh around 20 pounds!
Input wire is Homegrownaudio copper wire.  I also used it for the gain control wires.  PS and output wires are Electra Cable 16awg solid core copper.  Connectors were sourced from Parts Express.
I've read this giant thread a dozen times and have learned a lot.  This is my first solid state kit build.  I've previously built several tube preamps and amps as well as rebuilt a few Dynaco amps.  I'm pretty happy with it so far.  I've been wanting a big amp for a long time and for the ~$600 investment the classdaudio amp is working nicely.
I'll post more thoughts later.  Thanks to all of you guys for sharing your work and experience. :rock:
« Last Edit: 23 Apr 2011, 01:51 am by corndog71 »
mikeeastman
« Reply #2497 on: 22 Apr 2011, 03:54 pm »
I have a question about fusing. There are hi end fuses some fairly expensive but I don't see hi end fuse holders. Seems silly to put a $50 fuse in a $2 fuse holder.
corndog71
« Reply #2498 on: 22 Apr 2011, 04:11 pm »
Here you go.
http://www.acmeaudiolabs.com/
mikeeastman
« Reply #2499 on: 22 Apr 2011, 04:21 pm »
Thanks, exactly what I was looking for.
