$175 Class D amp--120 wpc
0 Members and 6 Guests are viewing this topic. Read 1217175 times.
Poultrygeist
Re: $175 Class D amp--120 wpc
« Reply #2400 on: 2 Mar 2011, 12:28 am »
I have the Sure Board/Meanwell PS and tube pre driving a pair of Zu's. Haven't heard the Class D but it must be dang good if it beats the TK2050.
boomer68
« Reply #2401 on: 3 Mar 2011, 11:14 pm »
I finally pulled the trigger and ordered the cda-224. I have read this thread it seams like a hundread times and looking forward to building my first amp.
Nick77
« Reply #2402 on: 3 Mar 2011, 11:22 pm »
Congrats........ :thumb: :thumb:
Post your build.
boomer68
« Reply #2403 on: 5 Mar 2011, 05:37 pm »
Thanks Steve.  The rca connections has the positive going to the center post and the negative going to the ring.  Hopefully, that is correct.
One thing i have a question about is the ground ring,does it go behind the white spacer or does it right against the nut?
Barry_NJ
  • So much media... So little time...
« Reply #2404 on: 6 Mar 2011, 12:58 am »
Between the spacer and the nut, not the spacer and the chassis, otherwise there is no need for the spacer ;)
guest1632
  • Guest
« Reply #2405 on: 6 Mar 2011, 10:54 am »
It goes behind the white spacer between it and the nut. You want each channel RCA floating. Otherwise you will definitely have a ground loop.
Ray Bronk
boomer68
« Reply #2406 on: 6 Mar 2011, 04:50 pm »
ok thanks guys
boomer68
« Reply #2407 on: 7 Mar 2011, 07:51 pm »
I recieved the amp today and i have a question
there is a purple wire coming off of the transformer what is that?
jtwrace
    • TIPP YouTube Channel
« Reply #2408 on: 7 Mar 2011, 07:55 pm »
It's a purple wire!   :P
boomer68
« Reply #2409 on: 7 Mar 2011, 08:01 pm »
lol i set myself up for that
boomer68
« Reply #2410 on: 7 Mar 2011, 09:19 pm »
[/img]
[/img]
Just a couple of quick pics to make sure everything works
Nick77
« Reply #2411 on: 7 Mar 2011, 09:20 pm »
You will need to contact Tom, but some of the transformers have secondaries that just get taped off.
boomer68
« Reply #2412 on: 7 Mar 2011, 09:21 pm »
boomer68
« Reply #2413 on: 7 Mar 2011, 09:22 pm »
boomer68
« Reply #2414 on: 7 Mar 2011, 09:23 pm »
yea i went back and read that it gets taped off. soo far so good we have tunes
jtwrace
« Reply #2415 on: 8 Mar 2011, 06:24 pm »
Is that your phone as the source?
boomer68
« Reply #2416 on: 8 Mar 2011, 07:31 pm »
Its my ipod touch
boomer68
« Reply #2417 on: 9 Mar 2011, 04:18 pm »
Been spinning vinyl sence last night and all i can say is wow! Im very inpressed with the sound of this thing.
The tightness of the bass is right there well worth the $175!
roymail
  • Roy in TX
« Reply #2418 on: 9 Mar 2011, 10:29 pm »
boomer68, great to hear you're enjoying the Class D amp.  :green:
pelliott321
« Reply #2419 on: 9 Mar 2011, 11:20 pm »
You guys are not going o like this.......
I bought one of these, sent it back for gain change, upgraded the PS by more than doubling the capacity and did a bypass with high audio quality cap, burned in for over 200 hours and I still thinkg it sounds most lacking.  No life, no envolvement.  I keep visiting this thread hoping to read that someone has found the magic bullet to make this thing sound like what you guys are whistling.
As it is its barely worth what I paid for it
