I am running 60kuf with no problems on the stock PS with Panasonic 10k TSHA caps, i think Wushiliu went even higher. I ran 40k for a while and bumped up to 60k with nice results, dont know if there is any benifit to going higher.Digikey has these back in stock for a killer price.http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P7492-ND
Aren't these caps rated too low for voltage? These are 63V - aren't the stock caps 80V?THanks,Lang
I'm at the point where I'd like to upgrade the power supply on my sds-258. The only decent quality caps I can find in a larger value that will fit the board are Nichicon KG 6800uf 80v. Not much of an increase in capacitance but I'm willing to try them just to see if there's a difference between the basic and premium Nichicon caps. As an alternative I could just swap the whole board for one of the Connex boards but I'm not sold on that. Is anyone aware of any other plug and play option out there for the power supply? Seems like an excellent opportunity for one of the commercial modder's on this site to step forward with a better solution.
Just my .02 but I do think the Connex SMPS500R performs head and shoulders above the PS setups I had before, and it's pretty much plug and play to boot. Terrific bass control. Same size as the amp board, too. Certainly lighter (and cheaper) than the monster toroid and premium caps you'd probably have to buy if you want to really step up your game. Win-win. I know someone was asking about using a Paul Hynes PS in his forum, so that's a possibility. But again, not cheap I'm sure... http://connexelectronic.com/product_info.php/cPath/25_46/products_id/118
That board is rated at +-54v which is ideal for the Class-D 254 boards, but the 258 boards need +-60 to 70.The only SMPS Connex solution that offers that much voltage is quite pricey...http://connexelectronic.com/product_info.php/cPath/25_46/products_id/120?osCsid=3kkel2uoqfdsc7r28v54p69fe7P.S. further poking around turned up this option, at a more affordable price, but it seems to be at the low end of the required voltage or just over max recomended...http://connexelectronic.com/product_info.php/cPath/25_46/products_id/124?osCsid=esalb5d1m7s390jauaqo28pvh5
8ch amp with 4 x CDA258 and a 2000w power supply would be awesome. Can the 2000w supply power 4 boards.
I find it utterly ridiculous that ebay is the only place to source 35mm wide 10000uf capacitors in the required 80v for my sds-258 . I have scoured every possible source with no luck. It looks like the 80v Nichicon KG 6800uf from partsconnexion is the best you can do with the power supply board from classdaudio unless you want to take your chances with what are more than likely fake capacitors on ebay.
