0 Members and 1 Guest are viewing this topic. Read 28818 times.
7.4 is a lot more responsive .............
Quote from: ctviggen on 1 Oct 2009, 09:01 amWhen I double click the Squeeze Server Icon, I get a control panel and that's it. Is that what I'm supposed to be getting? If so, I have to go back to an earlier version (and like an idiot, I deleted mine) -- I like using the computer instead of the remote to control what's playing and what I select. I'm not sure about how your computer is set up, but in mine, I have a SqueezeBox Icon in the bottom right in my taskbar. If I right-click on it, I get offered options. One of them is open web control.In MY system, I have encountered no bugs. It just works. There may be other programs running on some other systems that might cause some problems.Take a look through the Release Notes Wiki for more information about SB Server 7.4
Reinstalled 7.3
EmacWayne has the link on the first page
http://downloads.slimdevices.com/SqueezeCenter_v7.3.3/ try this
7.4.1 gave me the same results. I will stick with 7.3.3 until all the bugs are worked out
