0 Members and 1 Guest are viewing this topic. Read 11146 times.
...As far as the bass goes, where does the RM30 fall? Between the 626R and RM1, between the RM1 and RM2? The RM30s overall resolution is so beyond the prior models that comparing one part of the spectrum to another lesser model is difficult & possibly unreasonable. Even its bass quality is better. That said, if we were comparing only its overall tonal balance to another model, I'd estimate somewhere between the RM1 & RM2, but definitely closer to the RM1. The RM40 has less but higher quality bass vs. the RM2Finally, how will the RM30 stack up against the other VMPS offerings once they too receive the new crossover filter? ...
Brian, I too am quite interested in the new crossover. You say that this is the "the lowpass to the midrange" filter. B is posting about the filter passing low frequencies only, on the 6.5s & active 10 combined.Is this what separates the 10" Mega Woofer from the 10" Mid Woofer on the RM40s? No, absolutely not. The 2 active 10s are parallel with a sum total of one low pass filter acting equally on both woofers together. Beyond that each woofer has a different free-air resonance (Fs) causing the MW to cut out before the upper woofer, in spite of the single filter shared equally between the drivers. On the RM30s I believe that it would separate the 10" side-firing woofer from the two other cone speakers.Extremely unlikely. Brian has to my knowledge never (I assembled spkrs for him) used more than one LP filter on any combination of compound woofers. The 30M woofers are series/parallel but still have only one LP filter acting on all woofers combined. Same as the 40s woofers, the 6.5's higher Fs means it plays higher than the 10MW, in spite of the fact there is only one filter acting equally on the 3 woofers. Best wishes for the CES show and 2004.
Jim,How do you think an RM30 C would sound as a center channel sitting on an RPTV in an HT setup? This would have RM40's as FR/FL speakers. I understand BC would have the FST turned 90*Thanks
So maybe a horizontal RM30C will kick butt up there, with a slight tilt downward....
Brian, I too am quite interested in the new crossover. You say that this is the "the lowpass to the midrange" filter. Is this what separates the 10" Mega Woofer from the 10" Mid Woofer on the RM40s? On the RM30s I believe that it would separate the 10" side-firing woofer from the two other cone speakers.
What Brian is talking about here is the low pass from upper woofer to "MIDRANGE" driver or the neopanel. He is saying that the midrange neopanel will now cross-over at a higher point from the woofer below it. I believe he was playing with 180-220hz but haven't heard where it actually ended up. This would effectively move more air in the lower midrange and upper bass. As I stated in an earlier posting on the RM30, it also "frees up" the Neopanel to handle a smaller frequency range and this means higher output capability and overall performance which may allow the 3 neopanels to "approach" levels of the 4 panels of the (non-retrofitted) RM40. He is also saying that this x-over point can also be retro-added to some of the other speakers already in the field, for those interested in higher impact in the upper bass. This is relatively unimportant in Symphonic Pieces and light Jazz, but can be very valuable in rock and more modern music with high impact drum or percussive instruments, as well as Bass Guitar.
What Brian is talking about here is the low pass from upper woofer to "MIDRANGE" driver or the neopanel.He is saying that the midrange neopanel will now cross-over at a higher point from the woofer below it.I believe he was playing with 180-220hz but haven't heard where it actually ended up.This would effectively move more air in the lower midrange and upper bass.As I stated in an earlier posting on the RM30, it also "frees up" the Neopanel to handle a smaller frequency range and this means ...
While Big B did mention this possibility, I'm not sure I can see the horizontal implementation being as effective as say "head to head, dual 626Rs" as done by another VMPS'er here on AudioCircle. The limited dispersion of the FST being all the way to one end would seem to be a bit of a problem. (I could be wrong) Price wise it would be rather similar $1598 for the dual 626Rs and $1600 for the RM30C. In fact even the RM40 would probabaly work better since it has a centrally located ribbon tweeter (can any RPTVs take 240#???) Can you just see a horizontal RM40 on top of the new 80" Mitsubishi? I do think the best implementation of the RM30C is vertical and sitting just below a 50"-60" plasma, or behind an "acoustically transparent" screen. ...
Redbone,I'm not Brian or John Casler, but here's my understanding.Let's look at a signal coming into the loudspeaker. Make it easy on me and use a 3-way loudspeaker Further assume you are connected to the lower binding posts (woofers).OK, you have your jumpers connected, so you aren't going to biamp.The woofer crossover implements a "low-pass" filter. Frequencies below the crossover point pass through to the driver. Frequencies above the crossover are sent across the jumper cable to th ...
I'm sure if I've totally botched this both Brian and John will correct me
There has been a major change to the crossover filter, specifically the lowpass to the midrange, that has dramatically improved system clarity. This change will be incorporated into all the other ribbon speakers in our line and will be retrofittable. The changes involve about $50 worth of parts and can be done in the field. ...
It's good to see this change finally going on...it proves I was right (and not crazy) all along
