RM 30 Progress Report
0 Members and 1 Guest are viewing this topic. Read 11169 times.
Brian Cheney
    • http://www.vmpsaudio.com
RM30
« Reply #40 on: 4 Jan 2004, 04:33 am »
The Trinaural Processor has its own sub out (80Hz at 12dB/oct) with a level control.  It is an extraordinarily good sounding electronic crossover but set at too high a frequency for the 215/RM30.  So we have added a passive 6dB hinge point at 56Hz internally to the sub for a perfect blend with the RM30 all three of which will operate full range.
guest1121
  • Guest
« Reply #41 on: 25 Jan 2004, 06:43 am »
I might have missed this spec in one of the other RM-30 threads, but how much will they weigh?  Just curious...
John Casler
« Reply #42 on: 25 Jan 2004, 07:20 pm »
Quote from: Scott-C
The RM30M weighs 110# and is 4 ohms
guest1121
  • Guest
« Reply #43 on: 26 Jan 2004, 01:00 am »
Thanks John!
klh
« Reply #44 on: 14 Feb 2004, 06:30 pm »
Anyone at VMPS,
Have you guys thought of developing a horizontal center channel speaker to match the RM-30s that has one central standard HE/FS tweeter, two vertical Neo mids on both sides (four total), and two active 6.5s (one on each end). So it is...
       [(6.5)(Neo)(Neo)(tweeter)(Neo)(Neo)(6.5)]
Wouldn't make sense for the center channel to be symmetrical? And, since the center channel has the dialogue, wouldn't it make sense for there to be 4 Neos? If time alignment with four Neos is too difficult, what about if there is just one Neo on each side of the tweeter?
Just a thought... I bet it would sell well.
KLH
