0 Members and 1 Guest are viewing this topic. Read 5693 times.
I've read on another forum that Max doesn't work with it...just a heads up. I might install tomorrow and try it. Glad to hear that Amarra works with it.
Quote from: jtwrace on 28 Aug 2009, 09:24 pmI've read on another forum that Max doesn't work with it...just a heads up. I might install tomorrow and try it. Glad to hear that Amarra works with it.Ugh, that's a deal killer for me... Thanks for letting us know.
The way I understand it, if you have a unibody silver Macbook with the NVidia graphics card, you are good to go for 64 bit. If you have a black or white MacBook, you are limited to 32 bit. As far as the RAM requirement to see the 64 bit improvements, that is the first time I have heard that.
