0 Members and 1 Guest are viewing this topic. Read 5694 times.
Wow. Seems I got about 10GB of HD space back. Where did all that bloat go?
Crimson,No offense but don't add to the confusion. EFI64 Macbooks cannot boot to 64 bit with the 6-4 hold down. And I didn't mean intentional crippling, but the holding down of 6 and 4 (i.e. boot to 64 bit mode) does not work on EFI64 Macbooks (and of course not ever on EFI32 ones)...it is "crippled (your words)" by Apple temporarily until more apps are available and tested. For the rest of you...Mac Mini users, (or Macbook Pro, iMac etc) those users will find that even though their machine defaults to 32 bit kernel boots, they can over-ride by holding 6-4. I can't, even though i have an EFi64 machine. The only machines that automagically boot into 64 bit are the X-Server ones. Net/net, doesn't matter....rhetorical argument. The 64 bit kernel doesn't reach its sweetspot until later when Apple machines have 32 Gb of RAM, and we all can run 64 bit apps in a 32 bit kernel nicely anywho. My 4 GB machine would actually underperform in 64 bit mode (Mercman reports that in his 64 bit mode the Amarra/iTunes test sounded slightly worse than the 32 bit kernel...my point) ; I'm happy running 64 bit apps in my 32 bit world thank you.
Well I tried to install SL without a monitor and it didn't go that great. I use screen sharing with my macbook and after my mini rebooted part of the way thru the install I lost contact with it. I was able to reboot the mini and connect via firewire but when I tried to restart the upgrade process by clicking on the install disk it wouldn't let me. So I'm just wondering if anyone has been able to upgrade their mini without a monitor and if so, how?Sorry to read that your upgrade didn't pan out.You could always do a clean install and go back to Leopard.
