Got a couple off home improvement projects I need to complete before experimenting more with the panels. I still suspect the muffled sound you are hearing is the xps board you are using. I wonder if some shellac or something similar would help. ?? At least that is what I will try when I have a chance.
OB Newbie, firstly, don't think for a second that a DML will act like laser beam death rays at high frequencies and provide pseudo acoustic imaging tricks that so many audiophiles just can't live without despite all their direct radiator shortcomings.I find it strange that your attempt at DML 's produces a sound that is ''veiled'' (??????) and ''flat'' (?????). There is something amiss there as DML's are the opposite to this in my opinion.Also, you are using a SQUARE ( ) panel that is very thick and run by a more or less average exciter.........probably not a good match? Your room size, together with their positioning within that room, will also have a great effect on how these panels work. You say your panel material is pink, and others have mentioned blue?? . I came across the light blue stuff recently at the foam supplier and can say that it is definitely NOT the same stuff as VH GRADE EPS that I have been using (it was named ''XPS : SOVIRA BLUE''???. I don't know if this other stuff is what is causing anomalies out there, but I wouldn't be surprised. It is definitely NOT ''EPS''.By the way, the sound DOES come from the back of the panel.......it is supposed to and is what contributes to the magic of panel speakers.OB speakers that are primarily forward firing, are a different ball game, so forget about comparing the two systems and concentrate on improving the DML's.Once again on the subject of wide versus narrow panels to improve imaging.................you are not dealing with shoe box speakers on stands............the width of the panels do not act in this way (thank God! ).May I suggest you read ALL of the reviews found on the Podium website(as well as comments throughout this thread) so that you can fully understand that the DML is the only speaker type that can do what other speakers, including panel types, just can not. This is especially evident when compared to the sound of live music, which is what we audiophiles strive for. Rob.
Yes, ............but as far as I know, Podium have never released a "layered sound" loudspeaker.As a guess, they probably had significant trouble making it work due to the two totally opposite technologies and the sound they produce.Having attended numerous symphonic concerts, I have never noticed "imaging" as a real event occurring on stage. What I have noticed is the diffuse and homogenous sound field with lots of reflected energy (I actually heard the Tuba notes reflecting off the concert hall roof!!!)and some direct sound..........very similar to the effect of a DML in action.
Hi Ob Newbie.I have mentioned once before that I had a forum member from overseas visit me to hear my first version of the DML's when I was using black Gatorfoam.You talk about "dynamic contrasts"????........ ........when I played a percussion blast from a CD I have, he nearly fell off his seat!........and so did I!Instead of listening to rock music, borrow some real audiophile cd's of a different nature to hear what this technology can do. Listen to Yo-Yo Ma's "SOLO" (cello on it's own in a fantastic open acoustic) to hear dynamic contrasts and imaging. You want details to pop out at you?.........it's all there and every time I listen to it, there is something new to discover and it is NOT "spotlit"........that is unnatural.........more "hi-fi" than "real-fi".Anyway, I don't mean to create arguments , but there is a lot more going on in a DMLthan first meets the ear
Hi, For you guys that have only recently started experimenting I want to pass on something that I have learned. Over the years of OB's, horns, and others you learn quite a bit about what works well and why. That body of knowledge tends to close your mind somewhat to possibilities you might try if you didn't,t have that knowledge. I have found that what you think you know often doesn't apply with these panels. Since 2009 my assumptions based on knowledge built up over 40 yrs. have been shot down over and over. These panels don't play by the rules, so sometimes it pays to try things that you KNOW won,t work because with these sometimes it does. One EG., EPS . I always ended up rejecting it because of It's plastic sound. I thought I knew that any coating would not change it enough to satisfy me. It took me 6 years to get over my ignorance because of what I thought I knew.
JgaleAt the moment I am revisiting some of my older panels to see how they perform with the new sanding and pva method,as I type this I am listening to the new pink Floyd album (an Xmas present)on a 3mm thick 12x9 inch partially clamped panel it has a good response above 250HZ and very flat above 2.5k to 20k and this is only being held together with tape and g clamps ,I have them sitting on top of an old pair of Ditton 44s but just using the 12 inch bass units xo at 300HZ, I usually let the panels run down to about 100HZ, I would just like to say I am not championing small panels I am just saying that they do work and that if you have a small room and the other half does not want a 6ft panel you don't have to loose out on the panel sound.As for the presentation of the sound from the large and small panels,having a large panel in a small room IS like a massive pair of headphones, and if you switch between your headphones and the panels they should (if done properly ) sound very similar.With the small panels in a small room you will hear more depth and space around the panels and a little more delicate sounding maybe ,but you will not (as yet) get the full shock and awe of the larger panels.The small panels do sound good with drum solos ,better than most speakers I have heard ,but they just can't match the shear scale of the large panels ,swings and roundabouts again I'm afraid.unless you can get an OB to do the same but then your getting into large panels again.OB_newbieIf you would like a little more presence from the front of your 25mm thick panel I would suggest you try my method of sanding a cone type shape on the front side of the exciter of about 2inches wide and leaving about a 5mm thickness to the exciter,this gives the panel a more detailed and intimate sound ,I have mentioned this before on this site but maybe you have not read through all the pages,things tend to get lost in all the posts .Steve
AMEN!!!!Hi Ob Newbie, gosh yeah!.....those Telarc AND Reference Recordings are something to hold on to forever!!!!The absolute most INCREDIBLE, MIND BOGGLING, SUPER FANTASTIC percussion recording I own is : ''PERCUSSION XX''.......Jonathan Faralli........''ARTS'' label : 47558-2 ''audio Phile series'' 24/96 recording.If any of you out there can get hold of this recording, you WILL BE BLOWN AWAY!!!! ...............but beware!!..............so might your speakers!!!!
OB_Newbie, I am presently using 2'x4' panels with 15" Augies in an H frame. The combination works well. The 2'x4' need the help on the bottom. When I used 30" x 60" cardboard panels they didn't need that help. Neither did the similar sized birch panels I had. To my ears some form of OB bass is the way to go if the panels need help, U frame H frame etc seems to blend better than sealed subs or similar.
