0 Members and 6 Guests are viewing this topic. Read 1213887 times.
Hi OB newbie I hear the same as you in the bads, but is it not the DML that sounds this way ?If you want to stop theses panel sing from the rear, you can maybe damp it with some acoustic foam (like the one for speakers) but i think you'll probably loose some output SPL Here's some explanations from the creator of the podium sound panels:"Natural sound manifests two types of sound-waves: binaurally correlated and binaurally de-correlated waves. Binaurally correlated soundwaves are highly coherent, and among other things, permit us to determine where a sound source is located. Binaurally de-correlated soundwaves are highly incoherent, and among other things, permit us to estimate our distance from the source, or the nature and size of an acoustic space. The main problem with loudspeakers is their inability to propagate sound with both wave-types. This is an engineered limitation inherent in the mechanical nature of the devices themselves. Conventional cone loudspeakers propagate longitudinal waves. Longitudinal waves are highly coherent and binaurally correlated. Resonating DML type loudspeakers are transverse wave loudspeakers. Transverse sound waves are highly incoherent and binaurally decorrelated. It is simply impossible to propagate transverse waves with a conventional loudspeaker and conversely, it is impossible to propagate longitudinal waves with a resonating panel loudspeaker. No amount of DSP, loudspeaker placement, room treatment or other adjustments will change this simple fact. To reproduce natural sound, both types of loudspeakers are required.Layered Sound is the term used to describe the process of combining a conventional and a distributed mode loudspeaker, to produce the same audio signal. This combination, when used in the correct configuration, delivers to the listener sound that is clear, spacious, better imaged and more pleasant to listen toThe correct balance between direct and reflected sound is very desirable. When we listen to acoustic instruments in a concert space, we hear a blend of direct and reflected sounds. This combination creates the immersive effect we all enjoy and instinctively recognize as a natural sound. Unfortunately, conventional loudspeakers do not provide good reflected sound due to destructive interference and DM loudspeakers do not provide good direct sound due to their diffuse nature of transmitting sound. Not every loudspeaker is ideal for generating both direct and reflected sounds. However, conventional loudspeakers are well suited for direct sound and Distributed Mode loudspeakers are well suited for reflected sound. By combining these speaker designs according to the principles of Layered Sound, air disturbance patterns are created that physically emulate the sound waves of acoustic instruments, a natural sound. As a result, Layered Sound provides smooth diffusion, clarity and depth in any size room."so for him,with our brain and ears, DML is useful to know the position in depth of a source in a room and give the room infospistonic speakers are useful to know the panoramic position of it in the room hope this helps
OB NewbieIt's fun, isn't it? I'm new to it as well but here are some thoughts.
Are you using the Owens Corning Foamular insulating sheeting boards with the pink panter? I picked up the the 1/2" thickness R-3.0 from Home Depot labeled XPS insulation, film-faced insulating sheeting a few weeks ago. I havent had a chance to prep one with pva yet as many in the thread recommends, but after I read your note I tried just hand holding one exciter to the board. Keep in mind that the one I have hasn't been cut down in size yet so its 8 x 4ft. And yes, I also hear the hazy and flat sound you describe, which is very different from the clear and "vivid" sound I hear using birch plywood. I also want to get the good EPS sound I'm reading about so I'm curious to follow your efforts to see if similar boards can easily be bought in the US as well.
Using other panel materials I have found that I like slightly larger boards to get some lower frequencies. My 4x3ft panels go to about 60Hz before dropping, but unfortunately only 12k on the high end. Maybe it will be better once I run only 1 exciter vs four. I really wanted a square panel to work out for the look, but it didn't work out for me.
I like to get the panels off the ground and put two spikes (=nail with round head toward floor/stand) to allow them to move more freely and still support the weight. I found this to sound better in my set-up vs standing straight with the whole bottom edge on the on floor/stand. I also have velcro on the back of one of the exciters holding it in place on the panel stand. The only problem is if the music has really deep bass I get too much vibration so I need to put in a high pass filter.
Btw: Anyone has some good tips what's the easiest way is to put in a high pass filter?
I like the stereo image better if I step back a little bit from the panels- maybe 12ft (haven't measured) and have the panels toed in just slightly (not much at all)
+1. So called pin point imaging that some are so fond of is unnatural.It is never heard in live or real music. Having said that I can understand the fondness for it. I like the effect too, but since it is not natural we should not be critical of the panels for not giving us this unnatural feature. If we are honestly looking for close to a real listening experience the DML panels come closest and with the greatest clarity. How the reflected sound is managed becomes very important. My own room is long and fairly narrow. With the panels toed in about 45 degrees about 30" from the back wall (closest edge) and about 18" from the side walls I get a strong centre image. A vocalist sounds very real. My room is fairly lively. I realize that reflected sound is dominant in producing the experience, but then it is at a live event too. Coming from monkey coffins or horns the panels take time to get used to. I think it takes time to let go of the flaws that we are used to. With the panels I find that I listen to the music instead of listening to speakers. When properly set up the panels are almost unnoticed. Sedge mentioned a difference in presentation between small panels and larger ones. In my opinion 2'x4' is about the smallest size that is useful and then only if something else handles bass. The bigger the panel the more realistic the listening experience. Playing with panels smaller than 2'x4' is a waste of time--again my opinion.
