0 Members and 1 Guest are viewing this topic. Read 13641 times.
Will the audiovista phono pre take lomc's?
Hi John,Will the audiovista phono pre take lomc's?............
OK, MM it is for me then definitely. Thanks
I have been considering the AT 150MLX, Denon DL-160, Clearaudio Virtuoso Wood, Linn Adikt or Goldrign 1042. (the Grados hum in the Linn w/ AC motors) Any suggestions... anyone Thanks
MC version has too low a gain for really LOMC. It would depend on your preamp but I found myself cranking out past 80% to play my .3 mV output moving coil. HOMC or MM would be better unless Borris can increase the gain on this MC pre.
The MC version comes with 47 ohms loading and MM, 47K ohms (I asuume). Is the loading recommendation same for a typical MM and a HOMC?
