MM or MC?
0 Members and 1 Guest are viewing this topic. Read 13661 times.
Audiovista
    • Vista-Audio
Re: MM or MC?
« Reply #40 on: 14 Jul 2009, 03:48 pm »
Variations in actual output volume will depend on sensitivity and gain of the stages that follow - line preamp, power amp, speakers, listening habits....
You state it in a much more clear and succinct manner.  I have been referring to it as "overall system gain / sensitivity"  or "system gain / sensitivity profile".
I'm a master of (re)stating the obvious  :lol:
mgalusha
Re: MM or MC?
« Reply #41 on: 14 Jul 2009, 03:50 pm »
John R., if you like I have a Goldring G1012 that came off my Music Hall MMF-5, it has very low hours on it and you can have it if you like. It's a MM cart. The only catch is I have to find it and my basement is currently a mess due to construction of a shop. I do have an idea of where it may be tho.
andyr
Re: MM or MC?
« Reply #42 on: 15 Jul 2009, 02:54 am »
(the Grados hum in the Linn w/ AC motors)
Dave
My Grado Reference Platinum shows no hum on my AC-motored LP12.
Andy
boycephoto
Re: MM or MC?
« Reply #43 on: 15 Jul 2009, 03:19 am »
Hi Andy,
Please tell me more.  What power supply do you have in your LP-12? Do you have a high or low out put Grado.
I had a Grado Signature 7 back in the early 80's with a basic power supply in the Linn.  The closer the arm/cartridge (Ittock) got the the center of the record the louder the hum.  (the closer it got to the motor)
You have definately peaked my interest.
Dave
andyr
Re: MM or MC?
« Reply #44 on: 15 Jul 2009, 04:00 am »
Hi Andy,
Dave
Hi Dave,
Yes, I've heard of that happening ... but I've never experienced it.
My Grado Reference Platinum is 5mV output.  I have a Lingo1 powering my LP12.  The motor is the original (c. 1979) unless I had a new motor with the Cirkus or spring upgrade during the early 90s.
Andy
JohnR
Re: MM or MC?
« Reply #45 on: 15 Jul 2009, 09:05 am »
Awesome  :hyper:  The fourth stone has been located! Let the fifth element burst forth!!!
Thank you Mike :) I'll PM you. No rush - intercosmic deliveries are scheduled for September :D
mgalusha
Re: MM or MC?
« Reply #46 on: 15 Jul 2009, 05:59 pm »
Happy to help. I ran across it when I was clearing out all the stuff where they built the shop.
