0 Members and 1 Guest are viewing this topic. Read 26694 times.
greg, i really think you need to rethink your priorities. you have ~$400 retail speakers, and are wanting to spend >$2500 on a turntable? i suggest reversing the prices there - get some ~$2500 (preferably used) speakers, and get a $400 turntable. doug s.
Lazydays et al,Talking of belt drive ...I have been offered the opportunity to buy a Townshend Rock V with a cheap new Rega RB301 demo used only.Any thoughts on that?Greg
Woodsyi....three thousand three hundred pounds. Seems to be an emotive subject this Rock V some think it is the best turntable in the world ...others simply say cheap Rega innards...
Quote from: mountaineagle on 15 Jun 2009, 05:00 pmJohn,What cartridge, to date, do you best think suits the VPI Classic?GregI wouldn't know, Greg. Thus far two Grado's have sounded great on it (chosen as I really dig the brand and that VPI sells the brand....so I suspect the table was designed with them on it at one time or another)VPI also sells Dynavector....but, having never heard a Dynavector here (which I hope to change one day), I cannot comment on that one John
Do any of you guys think that you can design and build a better TT than Harry Weisfield. For all those (me included) that have fiddled with TT's, modifying them, changing this and changing that, we could have purchased a much higher end TT with the money we spent. I know for tweekers it the fun involved, but, the OP doesn't strike me as guy that wants to go through all that. He is getting back into vinyl and wants to buy a TT he can have confidence that will give him solid performance. I am not even saying the TT has to be a VPI Classic just something better than a SL-1200 that he can live with (no doubts) no muss, no fuss
Quote from: doug s. on 14 Jun 2009, 07:29 pmgreg, i really think you need to rethink your priorities. you have ~$400 retail speakers, and are wanting to spend >$2500 on a turntable? i suggest reversing the prices there - get some ~$2500 (preferably used) speakers, and get a $400 turntable. doug s.I believe that you spend the money on the source first! If you can not retrieve the subtleness of a micro groove, the best speakers will never make the music better. I have had this demonstrated and shown myself over the years. Give me the very best source component to start a system and I will fill in the rest with good, but less expensive items. This way i can also hear the improvements in the system as I choose new and hopefully better pieces to flesh out the chain.Many of the subtle things that you hear now will become things that are painfully obvious when they are taken away
Quote from: Curly Woods on 5 Aug 2009, 05:55 pmQuote from: doug s. on 14 Jun 2009, 07:29 pmgreg, i really think you need to rethink your priorities. you have ~$400 retail speakers, and are wanting to spend >$2500 on a turntable? i suggest reversing the prices there - get some ~$2500 (preferably used) speakers, and get a $400 turntable. doug s.I believe that you spend the money on the source first! If you can not retrieve the subtleness of a micro groove, the best speakers will never make the music better. I have had this demonstrated and shown myself over the years. Give me the very best source component to start a system and I will fill in the rest with good, but less expensive items. This way i can also hear the improvements in the system as I choose new and hopefully better pieces to flesh out the chain.Many of the subtle things that you hear now will become things that are painfully obvious when they are taken away get back to me after you have listened to a wintage used empire 208 w/a decent used aftermarket arm, like an o-l rega rb250... sure, when you get your $2500 deck, your $2500 speakers may sound better, but i would much rather be listening to the $2500 speakers w/the empire than using a $2500 deck w/$400 speakers until i can afford to upgrade ... and, of course, i listen to fm and cd as well - a $2500 turntable won't help the sound of those at all. ymmv,doug s.
How long have you been listening seriously? You are trying to tell me that they hear more with an expensive pair of speakers and a cheap frontend than vice versa? Good luck with that one my friend
oh, one other thing, my present analog front end isn't too shabby - oracle delphi upgraded to mkv specs, with o-l dc motor kit, fed by hewlett packard lab grade power supply. tonearm is o-l silver taper. so, i know a decent analog front-end when i hear one. and, i have also been fortunate enough to hear analog front ends even "higher-end" than what i own.doug s.
Well, Doug S. is right. You should hear my cheap turntables (Empire, Technics, VPI) on my Martin Logans. It is frickin' awesome. The tables also sound great on my AVA equipment in my studio. The real fact is that a good quality table with a modest priced cartridge can get you 99% there. The extra money on high end tables will not make you grin from ear to ear when you consider the cost difference, espcially when you go down the high end MC/exotic phono preamp path. This my friends is what John Thechairguy calls audiofooldom.However, it's your money and do as you see fit. I would much rather have the money spent on good vinyl.Wayner aa
