0 Members and 1 Guest are viewing this topic. Read 26436 times.
Quote from: doug s. on 7 Aug 2009, 08:57 pmoh, one other thing, my present analog front end isn't too shabby - oracle delphi upgraded to mkv specs, with o-l dc motor kit, fed by hewlett packard lab grade power supply. tonearm is o-l silver taper. so, i know a decent analog front-end when i hear one. and, i have also been fortunate enough to hear analog front ends even "higher-end" than what i own.doug s.Doug, I must apologize. I was more than a little snippy with my last reply. I have never heard an Empire Table with a decent arm before. I simply can not believe that an unsuspended table will have enough isolation to better a high quality suspended table. like your Oracle. I have been involved in high-end audio since the early 80's and hear so much BS that I often snap. Again I extend a sincere apology for my words.All the best,Michael Mastin
Doug,I wouldn't pretend to know anything but isn't the philosophy that you cant get out of the end anything better than you put in at the front?I deliberately put a ? because I have not heard enough audio to have an opinion on the subject and value yours.I have heard a point of view that you can just get a SL1210 because the phono stage is more important than anything else.I wish I knew all the answers as if I did ...within reason I would just go out and buy it.
Time out guys.... ....what about a Denon 103R for a stock SL1210 arm? Should I get a sumiko headshell or AT-LH18 headshell? The latter is heavier which I am lead to believe is better but one guy says it will warp the record and suggested a stock jelco headshell?I can get a sumiko headshell in the UK is it heavy enough? Do I need one counterweight or the second one too that comes with the deck?...Flashman thinks it will do the job?
Thanks Doug, I have learnt a lot by listening to you guys and its lots of fun ...has anyone had any experience of the audio vista phono stage? Would consider it if the limited edition has not already gone.Greg
