...And here is the link to the site of TRL products as well.http://www.tuberesearchlabs.com/index.htm ...
Listen to their products - and trust your ears. Then the lame site won't matter as much.
I have a McCormack 225 that I used with my HT1's. I borrowed the Moscode 401-HR for a month and found it much better than my McCormack with digital media through my Tact 2.2x. However, when I listened to vinyl through my tube Minimax Phonostage, I found that I prefered the McCormack! I wouldn't get the 225 with HT3's though, but the McCormack 500 might just be the ticket with your Manley preamp.BobPS Have you considered biamping?
Quote from: fsimms on 8 May 2009, 02:32 pmI have a McCormack 225 that I used with my HT1's. I borrowed the Moscode 401-HR for a month and found it much better than my McCormack with digital media through my Tact 2.2x. However, when I listened to vinyl through my tube Minimax Phonostage, I found that I prefered the McCormack! I wouldn't get the 225 with HT3's though, but the McCormack 500 might just be the ticket with your Manley preamp.BobPS Have you considered biamping?Hey Bob,I have a McCormack 225 and HT3's on order. My room is not too big (20 x 13 x 9) although it opens into the dining room and kitchen. Do you think the 225 won't have enough power? I'll obviously try it once the HT3's arrive. But if it doesn't provide enough power, I guess I'll be looking at some of the recommendations above.Thanks,Doug
I have a McCormack 225 now and HT3's on order. My room is not too big (20 x 13 x 9) although it opens into the dining room and kitchen. Do you think the 225 won't have enough power? I'll obviously try it once the HT3's arrive. But if it doesn't provide enough power, I guess I'll be looking at some of the recommendations above.
I recently purchased some used HT3's (thanks BRM!) and a Manley Shrimp preamp. I'm sure this combo has the potential to make me very happy, if I can find the right amp. - AVA Ultra Double 550. (Thanks for the loan Marty!). Nearly ideal. Mids and highs are nicely resolved and very musical. I only wish it had a bit more bass impact.
What is all this talk about matching an amp to Salk speakers? How can a good amp not be a match to a good speaker? How can you tell-hear if an amp is not matching? I' m asking because i know this is not about the low impedance driving capability of an amplifier. Or is it?
