0 Members and 1 Guest are viewing this topic. Read 26285 times.
I have preferred direct coupled solid state amplifiers with relatively high damping factors over
spectrum, but the middle down. So you try not to alienate these people. If you demoed with 10K amps and 2K wire a certain alienation would occur and the perception that this is what is
I like Jim's approach, I'd also like to fly him down to New Orleans and have him hear what his HT3's are fully capable of. Personally, having met Jim at his shop, I'd expect that he'd take note, but it wouldn't stop his enjoyment with modest front end gear one iota
Guys, this thread is steering quite far from the original intention and I dont see any help being given to the OP at this point. Lets try and clean it up and keep it on track. Constructive help is great, but grandstanding will not be tolerated.
Again and again, the underlying assumption is, "Come hear my really expensive stuff; it's better. Also, it's more expensive. It costs much more than the modest gear, which is modest because it doesn't cost nearly as much." Telling the manufacturer he hasn't yet heard "what his speakers can really do" is a bit off, isn't it?
Quote from: BPuckett on 26 May 2009, 09:40 pmI have preferred direct coupled solid state amplifiers with relatively high damping factors over Bad idea. Check Frank Van Alstine's back issues of Audio Basics for the full explanation of why "DC" amps never work.I've seen the effect on a scope and it isn't pretty. You're far better off using an amp with a high pass filter at the input and normal design with coupling caps.I've also heard "DC" amps going back to the Crown DC300. They produce what I call "lumpen bass."
Note that there are many people in the audio business that I would not trust to give an honest opinion. However, Jim strikes me as a straight-shooter and I think he wouldn't recommend something if he didn't feel it was good.
Why is it so hard to believe that something that costs more "could" be better? Not that it is automatically better because of its price tag.
Let's use Salk speakers instead of amps for a little exercise...Don't we all pretty much agree that as you move up Jim's speaker line the performance level increases? As great a value that Jim's products represent (based on many of our comments), does anybody believe that the HT3's are 3 times better than the Song Towers just because they cost 3 times more? Since I don't believe most of you feel that way, why are some people applying that logic to amps, sources, cables, etc...?
Again, I am not trying to impose my value system or viewpoint on anybody, I am simply asking that all viewpoints be considered and not make this into a black and white discussion.
Now, how about we get back to making recommendations to earsfirst and audiotom based on the criteria they supplied?
