fill in bass traps
0 Members and 1 Guest are viewing this topic. Read 1735 times.
keenween
fill in bass traps
« on: 28 Apr 2009, 08:52 am »
I am considering a few diy corner bass traps using 6" of rockwool. I would like to make the traps to look more like a large sack than a panel by adding bulk in front of the rockwool.
Any recommendations on what to use as fill? Would polyfill work?
I am not looking for additional absorption or reflection necessarily, just bulk!
bpape
    • Sensible Sound Solutions
Re: fill in bass traps
« Reply #1 on: 28 Apr 2009, 11:25 am »
Not sure exactly what look you're after.  Polyfill will be OK and not change the properties much.
Bryan
Rob Babcock
« Reply #2 on: 28 Apr 2009, 08:45 pm »
Interesting.  It it were me I'd probably just use more Rockwool since it's hard to get too much absorption at low bass freqs, but I guess the fill would be okay.  Seems like it would probably have some impact on the highs but I can't say for sure.
Sonny
« Reply #3 on: 28 Apr 2009, 09:02 pm »
Hi there, I use fiberglass fill, the pink stuff.
they sell in rolls, which works well.
T
keenween
« Reply #4 on: 29 Apr 2009, 12:03 am »
Thanks for the info! My listening area backs up to the kitchen dining area. I thought I would cover the traps in burlap and stencil on some coffee lingo so they look like sacks of coffee beans...try to improve the WAF.
Rob Babcock
« Reply #5 on: 29 Apr 2009, 04:43 am »
You might be able to get some burlap coffee bags for next to nothing; if you haven't looked at this already, check it out.
keenween
« Reply #6 on: 29 Apr 2009, 08:42 am »
I hadn't seen that! Thanks for the link...I'll have to call around and see if I can't find some!
