0 Members and 1 Guest are viewing this topic. Read 26636 times.
If I was doing it again today, I'd start with the Eminence or Goldwood. In fact I'm thinking of buying a pair to use for future OB experiments.
On the high-end side, aespeakers.com will build you Lambda Dipole12 or 15 woofers. But the cost difference is substantial. John usually gives a discount if you buy two woofers but my four Dipole12's where in the $800 neighborhood when I bought them in 2005.
Quote from: ultrachrome on 12 Mar 2009, 11:29 pmOn the high-end side, aespeakers.com will build you Lambda Dipole12 or 15 woofers. But the cost difference is substantial. John usually gives a discount if you buy two woofers but my four Dipole12's where in the $800 neighborhood when I bought them in 2005.AE also has the less-pricey IB15 and OB15 -- four for $400. Here are their specs: AE open baffle 15"s.
I happen to have a quad of the OB15, so they do exist. AE like a lot of businesses I patronize are little more than a 1- or 2-man shop -- Magnequest is another. An email to get info & pricing is hardly burdensome, and I might add that the dudes at AE are a pleasure to deal with.If a tricked-out website is the minimum benchmark for your purchasing $$$, then there's plenty you're missing.
I see many drivers from AE quoted with interesting specs and a wide range of prices. But when I go to the website and look at the "Products" all that is shows is the IB15. There is nothing with a "OB" or "Dipole" designation. The posted specs that have appeared on the AC forum look interesting, the price is unknown, and the availability and ordering info is not shown on the AE site. So I move on and stick with what I can find on PE's site.
These are the actual Lambda dipoles. Underhung motor, 12+mm Xmax, copper faraday so Le is only .0375mH with the dual 8ohm coils in series. Here are parameters for coils in series:Fs: 25.9HzQms: 11Vas: 273LCms: .7mm/NRms: .81kg/sXmax 12mmXmech: 18mmSd: 530sqcmQes: .73Re: 3.075ohmLe: .0375mHZ: 4ohmBl: 6.1TmPE: 100WQts:.68
Yea, I got a few of them. I can't speak of the drivers mentioned previously in the thread, but I can speak about the Augies.As far as the taughtness of the bass they produce, I'd call it "Tighter than a bulls ass on rodeo day".No sloppy mud here. No Sirree.The extra bonus is you can't hurt them, I've tried.Give me half a chance and I'll rant about them for hours. You'd be hard pressed to find a higher recommendation for Augies than from me.Bob
