0 Members and 1 Guest are viewing this topic. Read 14976 times.
Niteshade NS-50Specifications: * Power: 50 watts per channel full bandwidth * Frequency Response: 20-20,000hz * Tubes: 6L6 x 4, 6SN7 x 2, 5U4 x 1 * IEC Power Socket * Tunable Bias & Variable Negative Feedback * 60 Watt Output Transformers * Switchable Diode & Tube Rectifier Power supply * Compatible with: El34, KT88, KT77 and 6550 Tubes * CDE Commercial Coupling Capacitors * Semi-Gloss Ceramic-Based Finish
AudioCircle Member Combo Deal:This:Plus This:Get a Dual Tube Preamp PLUS the on sale NS-50 (One listed for $1750) for: $2500.00 Delivered. Free delivery is for the Lower 48. All other locations will have a discount. You get to choose the colors! Notice: If photos do not show up, the server might be down for maintenance.
