FYI - Just a heads up here on some product portfolio changes. Flexibility is key to a successful business, and so I am eliminating a whole bunch of HAL products. They are not quite right for today's marketplace realities. I spent a ton of money and time developing some of these machines, especially the HA-10, DA-10, and PA-10 line, but sometimes you just have to bite the bullet.
Now the HAL products comprise only the FRYKLEANER series of burn-in generators and the VACUTRACE. I do have three new designs in the works, which I will eventually bring out under the HAL banner. One is a full-function preamp with built-in phono and DAC sections. All tube, of course. The other is what used to be the concept PA-20, a high powered version of the PA-10 using four 6080 tubes per channel. I am aiming for 2010 or 2011 introduction. Oh, the third design is a tube guitar amp using EL84s.
The other change is the PICCOLO, which is now upgraded to use the same expensive capacitors as the HAL version had, but keeping the original blue casework. Not a spectacular visual beauty, but an absolute sonic gem, especially with the new caps. A bargain worth every dime.
jh
