Hagerman Audio Labs
0 Members and 1 Guest are viewing this topic. Read 14378 times.
alpa6
Re: Hagerman Audio Labs
« Reply #40 on: 23 Feb 2009, 05:45 am »
Hurray!Wtg jim!
amandarae
« Reply #41 on: 23 Feb 2009, 09:20 pm »
Time for me to save some dough!
My dream is to use the Original 50 Hz. pulley for my Garrard and reverse the pulleys of my TD 124's (don't know why?).  I tried PS Audio P300 but did not like the outcome.  My Teres runs on battery and speed is "dead on" ever since I assembled it, so no problem there.
Now, the most dreaded part of DIY........the waiting game!
Goodluck Jim!
Abe
analog97
« Reply #42 on: 24 Feb 2009, 12:51 pm »
I am having trouble understanding the benefits of such a device.  Below is a quote describing what the VPI TT controller does.  From what I gather, the important function is speed control.  But, claims apart from this about noise reduction, etc are tough to understand.  I have a VPI SAMA and it works very nicely.  When I check speed using my Hagerman UFO, all is fine.  The motor is completely isolated from the TT.  The only contact is between belt and pulley, so how is this device going to improve my performance.  Thoughts?  Thanks!
User friendly design, the SDS combines a turntable motor controller and line isolator into one 19" X 3" X 12" package. The SDS breaks new ground in clean accurate power delivery using advanced computer digital technology and quartz crystal accuracy.
The ability to adjust voltage and frequency being fed into a turntable motor was considered paramount in the design of the SDS. Both functions are adjustable from the front panel and results are shown in large, easy to read L.E.D. displays. All switching of speeds and voltages are done in a ramping fashion. There is no shock applied to the motor as the voltage or frequency is changed when moving between 33 and 45 rpm.
The circuit used in the SDS provides an incredibly accurate line frequency of great stability. Additionally, the electronic circuitry effectively isolates the output voltage from the input voltage, doing away with voltage spikes, low level fluctuations, RFI, and frequency variations.
Instead of merely filtering the power line, the SDS first changes it into pure DC voltage and then digitally regenerates its own clean signal. This approach is superior to that used in many of the other power line conditioners on the market.
The SDS works best with synchronous motor driven tumtables, such as those from VPI. The speed of a synchronous motor is determined by the frequency it is fed. It is only logical then, that a device whose speed is based on the line frequency will always function better when a stable frequency is delivered. A constant motor speed translates into a quieter, more faithful musical presentation.
Many historical recordings were not transferred onto modern records at the proper speed. Using the SDS, you can now correct the musical pitch of these recordings by varying the speed of your turntable. In addition, collectors who have VPI tumtables that run at 78 RPM will be able to accurately adjust them to compensate for the wide variation in recording speed used in the 78 RPM era.
