Center Channel for av123 Strata Mini
0 Members and 1 Guest are viewing this topic. Read 10869 times.
dvenardos
« on: 28 Jan 2009, 07:49 pm »
I am currently using an av123 Ref 100 as a center channel with the Strata Mini and would like a center channel that blends better. How does the Neo 3pdr sound compared to the planar magnetic in the Mini?
The O-3 looks like an interesting option as I can easily use a center tower for my center channel, assuming that Danny would sell me a single. :)
I am having the enclosures built for the AV-1RS which I will use as surrounds.
Thoughts?
Danny Richie
Re: Center Channel for av123 Strata Mini
« Reply #1 on: 28 Jan 2009, 10:38 pm »
The O-3 is a great option as a center channel if you can use a fllor standing design like that and if you can get it at least three feet out from the wall.
Another good option is a single sealed Neo-2X.
And yes, I will be glad to sell you singles of any of our kits if you like.
dvenardos
« Reply #2 on: 28 Jan 2009, 10:53 pm »
I don't think I can get 3' from the wall.
I see you can also build that as a ported tower to increase the frequency response.
Danny Richie
« Reply #3 on: 28 Jan 2009, 11:06 pm »
Yes.
dvenardos
« Reply #4 on: 29 Jan 2009, 10:46 am »
Hi Danny.  Not to beat a dead horse, but do you see the A/V-3S redesign with the Neo 3 pdr being available soon?
Yes, very soon. I have a guy building me a set of cabinets for it right now.
Is this still in the works?
phoenix_rising
« Reply #5 on: 30 Jan 2009, 01:50 pm »
Yes.
Hi Danny,
I bought a set of NEO 2X from you, do you have plans for a front ported box for them and if so could you please provide a link to it.
Danny Richie
« Reply #6 on: 30 Jan 2009, 03:22 pm »
Hank drew up some really nice plans for it but it is in a .dwg file. I'll have to figure out how to convert it to a pdf file or something. Maybe Hank can help with this? Hank?
BillB
« Reply #7 on: 30 Jan 2009, 03:41 pm »
How about a BG8 with an Atohm on either side and the tweet in a little pod on the top ala B&W?
If they offer Atohms in different impedences it might even be possible to use a single Ninja crossover to make it real simple.
Or could one of your woofers like the 130 or 160 be used and the x-over adjusted accordingly?
Of course it would have to be a custom fabricated enclosure but it would maintain the mini's driver lineup.
You could even build a stand that housed another powered 8" if you felt randy.
Hugh
    • Angel City Audio
« Reply #8 on: 30 Jan 2009, 04:18 pm »
Danny,
Email the dwg file to me then I'll convert it into pdf or jpg for you.
I sent you an email earlier this morning.
Danny Richie
« Reply #9 on: 30 Jan 2009, 05:31 pm »
Done with a big thanks to Dave for converting them.
See links below:
http://www.gr-research.com/pdf/neo2xside.pdf
http://www.gr-research.com/pdf/neo2xrearslot.pdf
http://www.gr-research.com/pdf/neo2xbrace.pdf
Note that the tweeter cut out was drawn for a different tweeter so you will need to used the driver spacing and drawings from the regular Neo-2X plans.
dvenardos
« Reply #10 on: 30 Jan 2009, 06:48 pm »
Now that would be THE plan Bill, but I think Danny is too busy for anything like that and as for me, well, that's why Danny designs the crossovers. :)
See links below:
Is the bottom section showing either a slotted port or a circular port? If not what is the bottom cutout for?
HT cOz
« Reply #11 on: 30 Jan 2009, 07:18 pm »
[/quote]
[/quote]
I believe that is the terminal cup.
Robert
dvenardos
« Reply #12 on: 30 Jan 2009, 07:23 pm »
 :duh:
phoenix_rising
« Reply #13 on: 31 Jan 2009, 05:05 am »
Danny,
Thanks Guys, Appreciated.
Jonathon Janusz
« Reply #14 on: 7 Feb 2009, 04:22 pm »
. . . a good question (I think anyway) here is where exactly to get the Atohm drivers from?  All I could find of them on the web (other than reviews of AV123 products) is the company's home page - in French and very poorly translated by google.  Do they have any US distributorship?  I checked partsexpress and madisound with no luck. . .
dvenardos
« Reply #15 on: 7 Feb 2009, 07:09 pm »
Danny says it would be a total redesign of the crossover to put it in a MTM configuration and no simple task.
The Ninja
  • Manufacturer
    • Skiing Ninja Systems
« Reply #16 on: 10 Feb 2009, 06:44 am »
>>>If they offer Atohms in different impedences it might even be possible to use a single Ninja crossover to make it real simple.<<<
They are available in 4 and 8 off the shelf.
>>>. . . a good question (I think anyway) here is where exactly to get the Atohm drivers from?<<<
Sourcing should not be an issue but I will check.
Jonathon Janusz
« Reply #17 on: 16 Feb 2009, 04:12 am »
Sorry I'm kind of late to the party back at this thread. . .
Sean, if you could source a set of mini drivers (and a stock crossover?) for the top part of the speaker, maybe the dream of a mini center could still be alive! :)
So, what's the internal volume of the mini top section and atohm driver enclosure anyway?  Could one of the PE cabinets be used for some quick-and-dirty prototyping?
Danny Richie
« Reply #18 on: 16 Feb 2009, 03:15 pm »
We are working on a new from scratch design.
emac
« Reply #19 on: 16 Feb 2009, 03:25 pm »
The fact that I'm reading "We are working on..." is enough to get me excited.
