0 Members and 1 Guest are viewing this topic. Read 56905 times.
you will notice a breakup in response above 10kHz that looks much like the diagrams Rudolf posted.The tweeter is on a 8" wide baffle...Perhaps what I see can be explained by things other than the baffle width, such as the design of the tweeter, but it seems to match what Rudolf posted.
Anyway, I am thinking about applying damping materials to the wide OB panels to overcome OB ballooning. In theory it should work. I have described my idea here: http://www.diyaudio.com/forums/showthread.php?postid=1716918#post1716918
With regards to applying damping materials to the baffles, I don't mean to attach fabric or thin blankets to the panel. I am thinking about adding the damping materials so that they form a shape like a donut. ... I could be wrong.
you only need a 6 dB LP at 80 Hz and a 6 dB HP at 500 Hz.
That's really nice and original pano.... post them pics when done !!Some people attempted waveguides for mid-high. I can only think this is beneficial for on and off axis response ?
I don't think it will change the 1st truth: OB rules ! /Erling
