0 Members and 1 Guest are viewing this topic. Read 26736 times.
John can I ask you why the VPI has no plasticlay? Seems damping the sub structure and the plinth ie:10 lbs worth, would level the field a bit.
What about the Rim drive, John? Really, I have one.
I listen to a direct drive turntable and I wear a belt around my waist.
John, have you tried Kevlar fishing line for a drive belt?Lin
Thanks Gary.I have some thread that is like monofilament (that I stole from the wife's sewing room) and I will try riggin that up this afternoon (in between a few brewskis) and perhaps a football game or two. I will try the knot, too.Wayner
Most dental floss is waxed.
Quote from: Wayner on 16 Dec 2008, 07:53 pmMost dental floss is waxed. It was explained to me on another site that the thread will pull the platter slower due to, I think I got this right, less material applied to the platter. Less potential energy carried from the motor, true, but less pulling power John
Was the diameter of the previous belt larger than the dental floss?
Nope. I'm at 7.
