0 Members and 1 Guest are viewing this topic. Read 36245 times.
Thanks for your insights!If I remember and understood correctly, the Isabella would require only the two signal lines. Could one just leave the lines providing voltage and ground unconnected? Or would one connect the mass to the shield? If yes: on both sides, or just one one side (but which)? As the connectors are dirt cheap, one could buy the fanciest cryoed silk whatever silver wires and still stay under 200$ for a home-made design.
6rs,,, it's a definte yes depending on the USB cable. Some make a little difference, others can transform your system, and I'm making this statement strictly on what I've found using 3 different USB cables in my system. I am presently auditioning Locus Design's Axis USB cable and I don't see any way I can part with it after witnessing what this single cable has done for my Trend's UD-10.1 USB transport. I've also heard god things about Ridge Street Audio Design's USB cable.I was on the fence also after replacing a Belkin Gold for a Kimber USB cable and didn't really notice any startling improvement. That has all changed for me within the last week as the Axis cable gets some miles on it. You will pay thru the a$$ for this cable but if you're not willing to make the sacrifice, whatevcer you do don't audition it. I say this with total honesty simply from what I've witnessed this last weekend from a simple Trend's unit. Those with better USB transporters/DAC's I would imagine will even be more impressed from the Axis. I plan on posting a thread on this subject after the Axis is totally broken in and I've done comparisons with the other cables. But I know my system pretty well and I'm doing things with it now in the higher volume region that would have been unbearable last week. For me, in my system, to say the Locus Design Axis USB cable has transformed my system would not be an understatement,, just pretty much dead on. Cheers,Robin
Hi all,been playing with Lee's Cryo-Parts USB cable for a week now and there is no doubt that it has brought good things to my system: more tonality, more beefier sound, more naturalness, more colour. It did remove digititus definitely, if there was some, especially at the upper end of freguency spectrum. I'd say it cleaned up the signal substantially .
Now I wonder how good an USB cable might Lee's Axis be? Thanks, Lee! Jouni
I think the signal wires are likely twisted and shielded, probably best to experiment with grounding the shield, also you might want to experiment with ferrite beads, the Kimber has them on both ends. I'd guess the USB power wire need not be used at all. I have some 28g mil spec wire... silver plated copper w/ teflon, in a twisted pair with shielding and a teflon outer jacket... this would probably work well and is very inexpensive if you can find it online. I just worry that all the usb plug ends currently available are going to be junk.
Robin,I just got one of Lee's Polestar USB cables to use with my Isabellina, and as soon as I get this laptop setup I plan to give it a try. Good to hear such nice things about it's bigger brother.I will say that this Polestar cable is exquisitely built and just oozes quality when you hold it in your hand. If it sounds half as good as it feels, it should be killer.-- Jim
Hi all,been playing with Lee's Cryo-Parts USB cable for a week now and there is no doubt that it has brought good things to my system: more tonality, more beefier sound, more naturalness, more colour. It did remove digititus definitely, if there was some, especially at the upper end of freguency spectrum. I'd say it cleaned up the signal substantially . Now I wonder how good an USB cable might Lee's Axis be? Thanks, Lee! Jouni
Hi 6rs,You still need to wire the 5V and GND lines of the USB cable. The USB receiver chip still needs the 5V from the computer - only for the Host pin so it knows to wake up and start looking for the signal transfer to/from the computer. Otherwise, it will not see the Isabellina. The actual power for the USB receiver chip comes from linear regulated battery power. This is why you must turn ON the Isbella/Isabellina for the computer to see it. However, do you not need the shield (but it is good for noise rejection).Also, BE CAREFUL with DIY'ing the USB cable - the USB receiver chip is sensitive and you want to make sure everything is connected properly - or damage can easily happen. It is also recommended that you use USB 2.0 (Hi Speed) cables for highest bandwidth, and make sure any DIY cables are constructed to these specifications. Again - be careful! It is not worth damaging your dac to try to hear differences between stock and DIY USB cables. Finally - try to avoid static charge and touching the other end of the USB cable when it is plugged into the dac. Again, it is sensitive and it is best to first unplug the cable from the dac, and then from the computer (if you are going to take it out of the system). You also should connect the cable with the computer and dac powered off. Then first boot the computer, and then turn ON the dac. Do the opposite for powering down. Again, this is recommended to avoid any trouble. This is not a "hot swap" device like a USB flash drive or something like that - this is a "delicate instrument" and care must be taken. Hope this helpsBest regards,Vinnie
Jim,I'm anxiously awaiting your thoughts on the Polestar cable. It's like 1/2 the cost of the Axis and I thought about trying that one out 1st but I heard so little difference between the Kimber and Belkin Gold plus the talk on Cryoparts entry level USB cable wasn't sounding all that great either. Considering Locus Design and Cryoparts are both Lee making these cables by hand, I wanted the best Lee had to offer. I am estatic I did, Therefore I'll echo Lee's advise, don't try the Axis in your system unless you're willing to buy it. The Axis is that good (IMHO). aaCheers,Robin
