0 Members and 1 Guest are viewing this topic. Read 14639 times.
For bass - If you want to build a good speaker you should use a mid .7 to .85 QTS group of several bass drivers per side on a flat baffle with no wings. Wire them to get the highest voltage sensitivity your amp will drive without compromise. The drivers should start out at decent sensitivity of 90 db or more each. The idea is to move a lot of air with low distortion and still have the ability to play loud enough to sound realistic with out the resonance nasties you get with wings, folds, boxes, or (insert your letter) frames.Biamping/triamping is pretty much mandatory and so is a good subwoofer. The sub should be of the front loaded horn type if you want the best blend and impact
That's one persons opinion, there will be others, be patient.Lin
While I subscribe to every statement Magnetar made about drivers above, I have different opinions (or even facts?) about baffle/frame geometries. But that wasn´t what you were asking for. Rudolf
I see allot of peeps run them through active crossovers....thats not my style (well not yet anyway).
>> just for the records/others: OB below the lowest room mode does not make sense at all>> Let me first talk about radiation pattern:I love real dipoles because of their dipole nulls perpendicular to the dipole axis.
>> In a moderately sized flat OB you will not get below about 40 Hz no matter what driver fs is used.
Please count me as 'others'; why does OB below the lowest room mode not make sense?
Anyone reading this could be put off before they start, and maybe miss out on clean LF reproduction to the excursion limit of the LS/drive.
The lower the driver Fs the cleaner the low bass reproduction.
Also, we don't get nulls perpendicular to the driver axis in a real room, that happens in free space only !
Quote from: MJK on 6 Oct 2008, 04:58 pm>> In a moderately sized flat OB you will not get below about 40 Hz no matter what driver fs is used. Again this could put folk off before they start.How low a baffle will output is related to cone displacement and drive.My baffle is flat and just 18" wide, but 30Hz is a doddle.
