0 Members and 1 Guest are viewing this topic. Read 14670 times.
Also it is room pressurisation which ruins LF reproduction. It might be something we have grown up with, and it can thrill our senses, but it is not what real live audio sounds like !When does any instrument on a stage pressurise a venue - they vibrate the air, and that is what he hear and feel. If we pressurise our rooms we are grossly distorting the reproduction.
My opinion is that there is not any suitable crossover point from dipole to monopole, only a LF limit for the dipole, whereafter adding a monopole ruins the open-ness of dipole bass.
I've got one 15" Hawthorne Augie per side in a 19'x12' room and get bass (-3db) to just bellow 30hz on an 18" baffle.
.So the operating range of any bass dipole is restricted to the dipol-loss-range below the lowest dipole peak. JohnK explains this in some of his Tech Studies: http://www.musicanddesign.com/tech.htmlIf you build a 21" wide H frame with a depth of 21" (front to back), the first dipole peak will be at ~320 Hz. This peak will in no way be "peaky" - just the upper end of the 6 dB/oct dipole roll off turning down to the first dipole null. This H frame will give you ~6 dB more efficiency than a 21" wide OB. Crossing over to your line array at 80-100 Hz you will be well away from that peak too, even with a low order x-over.That´s what I would recommend for your 'bass' dipole array.
