0 Members and 1 Guest are viewing this topic. Read 14640 times.
Quote from: Rudolf on 6 Oct 2008, 10:19 am.So the operating range of any bass dipole is restricted to the dipol-loss-range below the lowest dipole peak. JohnK explains this in some of his Tech Studies: http://www.musicanddesign.com/tech.htmlIf you build a 21" wide H frame with a depth of 21" (front to back), the first dipole peak will be at ~320 Hz. This peak will in no way be "peaky" - just the upper end of the 6 dB/oct dipole roll off turning down to the first dipole null. This H frame will give you ~6 dB more efficiency than a 21" wide OB. Crossing over to your line array at 80-100 Hz you will be well away from that peak too, even with a low order x-over.That´s what I would recommend for your 'bass' dipole array.Thanks for the link - I need to read this --------- 6 db more efficient is almost unbelievable. You have built and measured this comparision?
Quote from: Magnetar on 10 Oct 2008, 02:07 amThanks for the link - I need to read this --------- 6 db more efficient is almost unbelievable. You have built and measured this comparision?I read what I thought was related and found the author found a damped U frame was just as efficient as a longer length (36"!) H frame but I saw no comparison to a flat board.
Is the *efficiency* (per Watt) increased by 6dB, or is it the improved impedance match ...
Quote from: Magnetar on 10 Oct 2008, 02:23 amQuote from: Magnetar on 10 Oct 2008, 02:07 amThanks for the link - I need to read this --------- 6 db more efficient is almost unbelievable. You have built and measured this comparision?I read what I thought was related and found the author found a damped U frame was just as efficient as a longer length (36"!) H frame but I saw no comparison to a flat board. For what I measured look for the first diagram in my comparison: http://www.audiocircle.com/index.php?topic=49940.msg448752#msg448752I took MJKs worksheet to compare a H frame of 16" total depth for the Eminence Alpha 15" with a OB of same front area. That resulted in +5 dB from 20-35 Hz and +3 dB up to 150 Hz.
I think what's going on here are two things, the H frame is loaded / coupling with the floor better and the H frame is loading up the beet freq's in pipe resonance.
Quote from: Magnetar on 10 Oct 2008, 04:27 pmI think what's going on here are two things, the H frame is loaded / coupling with the floor better and the H frame is loading up the beet freq's in pipe resonance. We certainly can´t separate the effects from one another completely, so by and large you are right. But there is more to it. This H frame with a 8" long pipe has its resonance at ~280 Hz, which corresponds to a virtual pipe length of 12". This in turn is the effective dipole separation. Practically the H frame is donating a physical length that is optically not visible.Since you don´t exploit the H frame up to it´s resonance, that loading up is not part of the game. AFAIK the extra bass is generated by mass loading the driver with the lumped mass in the H frame.
Just though I jump in for a moment re a couple of things. If you make a careful comparison between and H frame and a flat baffle yuo will find that there are basically two differences. One is the added mass effect ont he H frame which lowers Fs, raises Qts, and also lowers effency. These effects are more significant for high effency drivers with low moving mass. Drivers with high moving mass, like the Peerless XLS woofer, show less of this effect. The second is the resonance peak of the H frame which is absent from the flat baffle. Also, the frequency of the resonance peak is a function of the length of the H frame and the cross sectional area. However, this does not alter the effective length of the H frame with regard to front to back separation or delay. For an H frame (or U frame for that matter) the delay associated with front to back separation is purely the path length difference. Coupling to the floor is not going to be significanly different for either.
John,I appreciate your clarification and extension. But I am not convinced yet WRT the effective separation length. If you are right, why don´t I measure any dipole peak or at least some plateau above (in frequency) the resonant peak? Do you know of any measurement or geometry configuration where one could separate the resonance peak of a H frame from its dipole peak? Will the path length be a "sharp" distance? Or could it be "smeared" between the length of the H frame and double the lambda/4 resonance wave length? I´m not sure whether the delay of an impulse response for instance would tell the true story?
