BRYStON BDA-1
0 Members and 1 Guest are viewing this topic. Read 114621 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BRYStON BDA-1
« Reply #240 on: 18 Jan 2009, 04:57 pm »
For now just out of phase is good enough,but i think you mentioned it above with the generally weak bass and vocals,thanks again.Whats funny is how some clearly hear and some dont.
Hi,
If the Left speaker vs the Right speaker is 'OUT OF PHASE' - meaning there is 180 degree phase shift between the two speakers then the whole concept of 'STEREO' three demensional sound goes to hell in a hand basket- these rules also apply to 7.1 and 5.1 setups.
The sound will lack bass, it will not have the ability to localize 'solid' images in space, or create a soundfield between, behind and beyond the boundries of the speakers. It will sound disjointed and there is a kind of wierd pressure on your ears.
The problem is usually quite obvious in a straight forward system but when you get to biwired and biamped systems or multi-channel systems it can be more subtle because it may be just the tweeter or the mid that are out of phase rather than the more obvious woofer.
The cure is to invert the positive and negative (black/red) speaker leads at ONE speaker and see if things get better or worse.
james
PS - as for 'some hear and some don't' bummrush, its like many things in life -you have to have experience and train yourself how to detect these issues. It's a learning experience.
« Last Edit: 18 Jan 2009, 06:21 pm by James Tanner »
ted_b
Re: BRYStON BDA-1
« Reply #241 on: 18 Jan 2009, 05:00 pm »
In regard to out of phase, it is very obvious to me, it makes my eyes cross (really  :D).
It would seem that some people do not hear it, I had a couple of auditions where one channel was out of phase, yet no one, including the dealer, could not hear it and insisted everything was good, till hours later they were proven wrong.
The phase switch of course doesn't address this; what you describe is a true setup problem with one red/black connection likely black/red.  A phase switch addresses absolute reverse polarity.  I insisted Dan Wright included one on his first pre (cuz I can hear absolute phase reversal fairly easily) and he's had one ever since.  However, although I now have remote phase inversion capability I seldom use it (like almost never) cuz as mentioned earlier, unless the recording uses minimalist microphone setup, the chances of multiple mic's and cables and limiters and preamps being all in the same phase is greatly reduced.....it's become a nit for me now.  I've heard pre's without one and don't list it as a prerequisite any more.  Nice to have, not need to have.
bob stern
Phase reversal: Audibility
« Reply #242 on: 18 Jan 2009, 11:09 pm »
James, I do find that correct phase makes a difference on 15 or 20 percent of my CD's.  On those CD's, the correct phase is more lively and spacious; the wrong phase is somewhat muffled.  For those CD's, phase reversal makes a much bigger difference than whether upsampling is engaged.
When you did your joint demo's with Thiel at various trade shows in the last few years, did the Thiel reps ever express any interest in flipping the phase switch on the BP-26?  If not, that would seem an implicit admission that Jim Thiel's efforts to achieve phase-aligned loudspeakers are pointless.
konut
Re: BRYStON BDA-1
« Reply #243 on: 19 Jan 2009, 12:15 am »
It would be nice to have the option, if not difficult to implement. Those who do not need, or care, are free to ignore.
vegasdave
Re: BRYStON BDA-1
« Reply #244 on: 20 Jan 2009, 04:23 am »
HI All,
Have an English translation of a review on the BDA-1 from the French Magazine 'Sound and Image'.
PDF- is 2M
Email me at [email protected]
james
http://www.audioadvisor.com/pdf/BDA_1_DACReview.pdf
ian.ameline
Re: BRYStON BDA-1
« Reply #245 on: 20 Jan 2009, 04:52 am »
Nice review -- it's a shame he didn't realize that he could have listened to the 24/96 tracks with no down sampling or resampling merely by plugging an optical toslink cable into his mac-mini to connect it to the BDA-1, and using the audio/midi control panel to set the digital output to 24 bit, 96Khz.
Re: BRYStON BDA-1
« Reply #246 on: 20 Jan 2009, 12:41 pm »
Hi Ian,
He was so impressed with the BDA-1 he purchased it for the Magazines testing lab so I will pass on your suggestion-maybe a follow up review is in the cards?
james
KeithA
Re: BRYStON BDA-1
« Reply #247 on: 23 Jan 2009, 11:46 pm »
The BDA-1 in its new home....some pretty good other Bryston /Torus representation as well :thumb:
Keith
mr_bill
Re: BRYStON BDA-1
« Reply #248 on: 24 Jan 2009, 12:33 am »
Nice System!
Are you using a Cambrige 840 CD player with your BDA1?  Isn't that a sideways move?
niels
Re: BRYStON BDA-1
« Reply #249 on: 24 Jan 2009, 12:47 am »
No, he is using the Squeezebox....ha ha.  aa  :thumb:
KeithA
Re: BRYStON BDA-1
« Reply #250 on: 24 Jan 2009, 01:41 am »
Nice System!
The Cambridge CD player (it's actually one of the lower versions, 540C) is what I was using for a transport before I got the Squeezebox (Duet & Classic). It's still in my system for times when I want to play a CD that's not yet ripped to my hard drive (for example, if someone brings a CD over for me to try out).
It is turned on today (maybe the 2nd or 3rd time in a year :o) since I was playing some new CDs I got for Christmas that are not ripped to my hard drive. Both the CD player and Squeezebox feed the BDA-1 as transports. The CD player is not being used analogue. 99.9999999999999% percent of the time I use the Squeezebox. The Squeezebox sits atop the little white cube on top of the stand. After today, the CD player may not be used for another year :lol:
Keith
vegasdave
Re: BRYStON BDA-1
« Reply #251 on: 24 Jan 2009, 04:49 am »
Nice System!
Why would it be a sideways move?
KeithA
Re: BRYStON BDA-1
« Reply #252 on: 24 Jan 2009, 11:44 am »
Nice System!
Just a guess........
I suspect since if it was the 840C, many people view that particular player as a 'giant killer' in it's own right. So, if I had a 840C and upgraded to the BDA-1, many people would see the quality as comparable. The 840C at US$1,599 has gotten some pretty good reviews. Hence, a sideways upgrade or no real increase in audio quality.
Keith
mr_bill
Re: BRYStON BDA-1
« Reply #253 on: 24 Jan 2009, 03:59 pm »
Correct.
vegasdave
Re: BRYStON BDA-1
« Reply #254 on: 24 Jan 2009, 08:31 pm »
Nice System!
Keith
I see. I don't. The 840C is made in China. Not something that I'd want. I'd rather spend my money on the Canadian handcraftsmanship that Bryston provides. Also, is the analog circuitry and the transformers comparable to the BDA-1? I don't believe so.
KeithA
Re: BRYStON BDA-1
« Reply #255 on: 24 Jan 2009, 10:04 pm »
Absolutely. That's why we are here :wink:
Keith
vegasdave
Re: BRYStON BDA-1
« Reply #256 on: 25 Jan 2009, 04:07 am »
Cool. I'm glad you agree.   8)
KeithA
Re: BRYStON BDA-1
« Reply #257 on: 25 Jan 2009, 12:58 pm »
But I also see nothing wrong with the Cambridge gear. The little player I have is solid.
Keith
Frisco
Re: BRYStON BDA-1
« Reply #258 on: 28 Jan 2009, 09:01 pm »
KeithA nice set-up  :thumb:
James...I just got your PDF on the BDA-1....thank you....I sent an email to Shane(HiFi Hawaii) and he says your DAC is "awesome". It looks like my shortlist for a Dac just got shorter. It looks like my time frame for a Dac will be about April.... Tax time(hoping for a refund)   I know that's a couple of months away from now but how is the backlog looking now for the BDA-1? weeks? month?
One more question...I'm curious on the amount of people ordering the black or the silver faceplate?  :scratch:  I'm partial to the silver myself  :drool:
Thanks again James  :thumb:
Re: BRYStON BDA-1
« Reply #259 on: 28 Jan 2009, 09:12 pm »
Hi Frisco,
About a month with a new order.
Silver sells about 2 to 1 and 17 inch to 19 inch about 3 to 1 (I like the 19 inch but that's my pro side speaking)
james
