BRYStON BDA-1
0 Members and 1 Guest are viewing this topic. Read 114610 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re:Bryston BDA-1
« Reply #340 on: 7 Jun 2011, 07:32 pm »
James,
Now that we have 24/192 USB chips, will you be offering an upgrade option?
Hi  - can you direct me to the chips you mentioned?
james
adol290
Re:Bryston BDA-1
« Reply #341 on: 7 Jun 2011, 11:43 pm »
james
Sorry James, my bad.
I got confused between USB 2.0 supporting high bit rates 24/192.
I assumed other vendors were using a chip solution, BUT
 realized it was software specific drivers, created on the windows/mac side.
Hence the BDP-1 -  a dedicated linux system.
AnhTuan
Re: BRYStON BDA-1
« Reply #342 on: 21 Aug 2020, 01:51 pm »
Dear James,
I am Tuan from Vietnam, I have been a fan of Bryston and I have spent for 7 years to collect Bryston equipment (very hard to find in Vietnam). My current system are: 3B THX, B60 SST, and BDA-1.
I would like to have your support for solving my BDA-1 error as following symptom:
The BDA-1 manufactured in 2011. Yesterday when I turn it on but there no any signal out. The led light both at Up sampler and Power are all in Red. I turned up again but all led in input positions did not light up.
Could you please give me a guidance to sole this problem of my BDA-1
Thank you very much and looking for your help.
With my best regards,
Re: BRYStON BDA-1
« Reply #343 on: 21 Aug 2020, 03:04 pm »
Dear James,
Hi Tuan
Mike will be in touch.
james
fado
Re: BRYStON BDA-1
« Reply #344 on: 21 Aug 2020, 04:35 pm »
If its the battery, advise him on the best way to remove the old battery. I just pulled up on mine and the whole battery holder came out. I was able to solder it back in place keeping the + and - on the holder in line with the corresponding + and - on the circuit board - (not pretty) but it works. After examining the holder, there is one side to lift first and there was nothing underneath the battery that would be damaged by the careful insertion of a small straight blade screw driver.
AnhTuan
Re: BRYStON BDA-1
« Reply #345 on: 22 Aug 2020, 02:38 am »
Dear Fado,
Many thanks for your suggestion.
I have checked the internal of BDA1 via picture on the website but did not see the battery on the board. I though the battery just only available in BCD or BDP, not in BDA. Could you please let me know your equipment is BDA or BDP/BCD?
AnhTuan
Re: BRYStON BDA-1
« Reply #346 on: 22 Aug 2020, 02:41 am »
Hi Tuan
james
Dear James,
I have received email from Mike with his guidance.
Thank you very much.
fado
Re: BRYStON BDA-1
« Reply #347 on: 22 Aug 2020, 06:14 am »
Sorry, I was thinking of my BDP-1. I do not have the BDA. Thanks for catching that. Good luck with your project, AudioCircle members are an enormous source of information.
AnhTuan
Re: BRYStON BDA-1
« Reply #348 on: 22 Aug 2020, 06:31 am »
Dear James and Mike,
According to your instructions, I have successfully updated the firmware and my BDA-1 cured.
I appreciate your prompt and timely support.
