0 Members and 1 Guest are viewing this topic. Read 19660 times.
First, right off of the bat -- YMMV.Now. I have not found a 4" full-range speaker that does convincing bass any anything but VERY polite SPL. I personally personally wouldn't use a 4" driver alone for anything stronger that "a girl and a guitar". I would use a 4" driver as a mid-tweeter crossed over to a 10" or 12" driver in the 300Hz range. That said there are a lot of guys that are tickled pink with 4", even 3" single driver speakers.I have built successful 6" single driver speakers. Moderately good bass to 40 Hz. Pretty good top end if not too far off axis. You can actually get 80dB at a reasonable distance.I like 8" drivers. Solid bass into the 30's. Actually have some grunt in the upper bass that you need for rock. Top end is often weak. Many, at least those guys who haven't destroyed their ears at rock concerts, add tweeters rolled in above 6kHz. I consider this the sweet spot and all of my serious listening on a pair of 8"ers.One man's opinion.Bob
Several ways to look at this question, so I see no easy answer. Ed Schilling from The Horn fame has a compelling argument on his site for 4 inchers. But the physics involved say the 4 incher have a hard time generating much deep bass regardless of cabinet design, etc.
The smaller drivers don't have whizzers. (This topic could generate a whole series of threads by itself.) Again, those same physics say that a small whizzer shouldn't "beam" high frequencies as much as 4 inch driver without a whizzer. Fostex also has a F120A driver that goes deeper, less efficient, and uses an AlNiCo magnet but doesn't offer anything like it in a 6 or 6.5 inch size. So this rather unique driver throws a hard curveball into this discussion.
6 inch drivers usually have whizzer cones, but roughly double Sd (surface area) to push more/deeper bass. Physics (and specifications) show all else being equal that larger drivers are more efficient as well.Fostex makes multiple drivers of the same size to suit different applications and taste. If you're in a small room/setting or will be using a subwoofer a 4 inch driver could be ideal. OTOH if your interest is primarily listening to small ensembles, a 6 inch could make a lot of sense.So it often boils down to expectations. Single drivers offer many advantages, but so far there is no perfect speaker. Expectations, application, and tastes are the keys to single driver bliss.
