0 Members and 1 Guest are viewing this topic. Read 19656 times.
so full of BS
Hopefully, we can all accept the fact that this thread has gone off topic. It's not really about enclosure designs, but about a preference for specific driver sizes. Pros and cons between 4.5" and 6.0" (and probably extended to 6.5") drivers made by Fostex and what the group members think about these and why they choose one over another. Currently, Fostex make 4 product groups of FR drivers, F, FE, FF, and FE-sigma. Hopefully we can forego the BS on enclosures and get back to discussing the drivers. Just a thought. Regards, KM
Bass and peak SPL is reduced in OB but sound is pure unlike BLH.
Mr Maynard, Did I say I use a helper woofer? Maybe you and Ed should carefully read posts before jumping to wrong conclusions.
Choosing a FR means you have to choose your tradeoffs... i'll just tick off a general ones ...1/ bigger drivers tend to be more efficient than little ones (which mean they play louder with a small amp)2/ smaller drivers usually have better mids & tops.3/ bigger drivers go lower & tend to be able to do dynamics better4/ small drivers usually go in smaller boxes, with higher WAF, and lower cost to build5/ bigger drivers tend to cost more (and i haven't meet a driver i can't improve)6/ and a corollary to 5... a well modded small driver for the price of a similar priced large driver will usually have more finese. (disclousure: i sell modded drivers)
