0 Members and 1 Guest are viewing this topic. Read 35285 times.
All I do is to STOP and then EXIT slimserver/squeezecenter and then start the software up again.
.....you can look at the player info page on the unit itself and it will tell you the IP address......On the server, you should be able to go do a DOS prompt.
Did you do the DOS command I gave you? That's your real IP address for the server.
Sometimes the router just needs refreshing. Turn the router off for a minute and turn it back on. Then retry. I know it's a low tech method, but it usually works for me.
You sure it's 192.168.0.1? Usually, the modem/router/etc. will be 192.168.1.1 and the PC's will be 192.168.1.100, 101, 102, etc.Did you do the DOS command I gave you? That's your real IP address for the server.
Cool! I have hammers too. Just in case.If things get real nasty, I've got a pneumatic hammer we can use.Nothing better than beer and power tools to fix a PC problem. aaBob
