0 Members and 1 Guest are viewing this topic. Read 35324 times.
Step 1:Access the router’s web-based setup page. For instructions, click here.
When you do that (hold the reset), according to the site, you'll get a screen to confirm (if you're connected). Either way, we'll KNOW what the IP address and uname/pwd are for the router.
After you do the hard reset like that - just go do the DOS prompt and type:PING 192.168.1.1 and hit ENTERIf it comes back with addresses and return times, we're getting somewhere. If not, then it could either be a bum router or a bum cable as has been suggested.
There have been a few instances of routers getting 'stuck'. In that case, you hold the reset for a minute and at the end of the minute, keep holding it while you unplug from the wall. Leave it unplugged while holding the reset and plug back in. After 30 seconds release it. Seems odd but that's right from the Linksys support forum.If you have to do this second part, you'll need to repeat the PING afterward.
Connected ethernet cable to different 'output' port on router.Repinged 192.168.1.1: "4 packets sent = 4 packets received"
Then you just reboot the PC and the SB so they can get new IP addresses from the hopefully now working router. Go through the SB setup again, select DHCP for a new IP address and pick the slimserver host by host name, not IP.
Quote from: richidoo on 9 Aug 2008, 02:57 amThen you just reboot the PC and the SB so they can get new IP addresses from the hopefully now working router. Go through the SB setup again, select DHCP for a new IP address and pick the slimserver host by host name, not IP. IT'S ALIVE ! This morning I rebooted the PC and yanked the plug on the SB.It works!Strangely enough, I did not have to go through any set-up procedure.Should I? ........ Or should I leave it alone?The VU meters on the SB happily swinging away. Thanks guys, Bryan, you wanna come over NOW? aa I promise I won't put you to work this time. Bob
Yea better get some cold one's for Bryan
One way of troubleshooting the integrity of the network, if the slimserver/pc is flaking out, is to test whether the SB3's internet radio is working, but with the PC modem setup????
