0 Members and 1 Guest are viewing this topic. Read 12407 times.
I don't think bigger is better. My in-laws went with a 50" and they sit too close and it is blurry that close. Big can be too big. Most broadcasts on a 50 look like dog s**t.
Quote from: PMAT on 27 Jul 2008, 05:03 amI don't think bigger is better. My in-laws went with a 50" and they sit too close and it is blurry that close. Big can be too big. Most broadcasts on a 50 look like dog s**t. Blurry? What kind of 50 inch do they have and what is the signal feeding it? Any LCD or plasma is going to look terrible with a bad signal. I've never seen 1080p or 720p look blurry. In the right settings, you can be 10 feet from a 50 plus inch flat panel and it will not be blurry. Sounds like your in laws bought a crap TV or crap signal to feed it.
Quote from: GHM on 27 Jul 2008, 05:47 amQuote from: PMAT on 27 Jul 2008, 05:03 amI don't think bigger is better. My in-laws went with a 50" and they sit too close and it is blurry that close. Big can be too big. Most broadcasts on a 50 look like dog s**t. Blurry? What kind of 50 inch do they have and what is the signal feeding it? Any LCD or plasma is going to look terrible with a bad signal. I've never seen 1080p or 720p look blurry. In the right settings, you can be 10 feet from a 50 plus inch flat panel and it will not be blurry. Sounds like your in laws bought a crap TV or crap signal to feed it.Not every TV signal out there is the quality of Blu-Ray. I know exactly what PMAT is saying as there is crappy cable, OTA, and standard digital channels available that will give you an undesirable picture, even on my 36" CRT w/DirecTv and it only gets worse as the set gets larger. The quality of available signal on the channels/source that you'll be watching should play a large part in what type of set is being purchased imo. Cheers,Robin
But, if a few hundred more will get me a perceptibly better picture, I can.
A 42" screen is preferable.
I'm told that 120Hz processing is making LCD smoother.Visio has a new model out this month with this and 6500:1 contrast ratio (I don't know what the practical value of this or any number is). I don't know what the refresh rate is at this moment but I understand this, too, is important to a smooth picture on LCD. The higher the better, right? Or, is it the other way around? And does this actually translate visually in any appreciable amount (i.e. football games). BTW, I don't care about vidio games. It is a 1080P. The price is right. Visio has no snob appeal so I'll have to eat s___ from my brother in law. He has a 42" KURO and it looks very good. But is this a good TV or what?
I am not locked into LCD it is just that it seems more practical than plasma altho I know plasma as a rule has deeper blacks, less motion artifacts, better depth perception. I'm hoping that the aformentioned developments have narrowed the gap.
Questions: Do LCD sets do video processing (DVD's) as good or better than plasmas or is that manufacturer dependent?
On my analog set, I have a variable out. I can use a couple of monoblocks I have to power my speakers and control the volume with the remote. I really would like to be able to do this on my new set but is this going to be possible with modern sets?
At my local Best Buy there is a discontinued Samsung 50" plasma-new-for $1799.00. I could fit it in, I suppose. That Visio is $1399.00. I do watch a lot of DVDs. I'm gonna get an OPPO.
I will appreciate your experience and take on the future. Recommendations, too. Thanks more than I can say.
Dan, all- 42" will fit the space available better. Viewing at approx 8'. LCD alledgedly uses less energy and will last longer. Anybody?My amps drive the speakers direct. No preamp available. Hence, I need to be able to control the volume from my remote. Will analog out permit me to do this or must I have a variable out?I read that shoot out between the Samsung LCD and the Kuro. Both are pretty expensive so I have ruled them out. The Visio is less expensive by a long shot. American made, too, I think. But, I don't wish to compromise the picture versus a competitive make. And, yes, there is quite a lot of light in my viewing room. A lamp stays on between two chairs directly in front of my set. My wife reads a lot. The OPPO upsamples, no? I've read only good things about this unit. Is it terribly short of Blu Ray? Will it do the best or near best with my existing DVD collection? Only one was filmed in high definition- Collateral (Michael Mann)- and the picture is drop dead gorgeous even on my analog TV.Thanks, everyone. Kindly re-visit me if you have something to add. Cheers.
