0 Members and 1 Guest are viewing this topic. Read 19010 times.
Barry,Here are a few candidates:BAT VK600SEPass XA 100.5I definitely preferred the BAT in every way to the Moscode and I think that the Pass amp would be an upgrade as well.Both can be had well under $10k used.George
George, you mean even when it comes to midrange, the BAT is more liquid/smoother than Moscode? aaI bet you regretted selling the BAT for Moscode two years ago...
Quote from: AliG on 6 Aug 2008, 10:41 pmGeorge, you mean even when it comes to midrange, the BAT is more liquid/smoother than Moscode? aaI bet you regretted selling the BAT for Moscode two years ago... I didn't sell the BAT for the Moscode...the BAT simply didn't fit my system when I switched to a fully loaded Bolder Cable SB2. While I liked the Moscode, it definitely wasn't in the same class as the BAT.If I needed a high power amp, the BAT would be up at the top of the list.Couldn't really find any issues with its performance...only issues are size and the amount of electricity it uses. George
Quote from: arthurs on 24 Jul 2008, 01:07 amThe Sunfire will surprise you Pete, damn fine amp......Also in the back of my mind is Jim is promising higher efficiency on the HTX speakers and perhaps a lower powered tube amp might be worth trying then.
Quote from: Big Red Machine on 24 Jul 2008, 01:14 amQuote from: arthurs on 24 Jul 2008, 01:07 amThe Sunfire will surprise you Pete, damn fine amp......Also in the back of my mind is Jim is promising higher efficiency on the HTX speakers and perhaps a lower powered tube amp might be worth trying then.I really liked my Sunfire 200w x5 amp; never ran out of smooth power, should have kept it. Totally bulletproof. I'm very curious of your opinions vs. the Pass. If your speaker's impedance curve is flat enough you could consider an Atma-Sphere OTL. On the right speakers they are my favorite. Prices may surprise you: 30W stereo (you may need more) estimated $2700 MSRP. Duke LeJeune can flatten one impedance peak w/ an outboard passive device w/ no acoustic penalty (wired in parallel, nothing series). He also sells new Atma Sphere.
The Sunfire has far superior bass than the Pass 350.5 I had. I think the Pass was more direct and actually smoother on the top end but I'm tapping my foot with the Sunfire for sure right now. I may bring in an older Spectron to compare to the Sunfire.
Sunfire = Surprisingly good.... aa
Quote from: arthurs on 7 Aug 2008, 12:48 pmSunfire = Surprisingly good.... aaI'm quite satisfied but still so curious to try a Spectron and see if it does it ALL. Such a pain to buy and sell like this.
Based on my limited experience having a Spectron III in my system (a couple of hours) I think it would take you another step up from the Sunfire, but as suggested by rydenfan, maybe an in-home demo would be the best path...
When I started to work on Mk1 Signature in my beginng of Spectron career, 100% of my attention was on "magic" - this capacitor vs that capacitor, this wire vs that wire etc etc (for my ears standard Musician III was a bit sterile). When, about three months ago, we finished Mk2 - I suddenly realized that I don't care very much about these "magic" things - changes in design; first formulating the right question and then answering it bring much, much, much, much... much more changes to sound then "magic capacitor". For me personally it was rather stange discovery. I did not expected it.
