0 Members and 1 Guest are viewing this topic. Read 19458 times.
I can always go back to a Pass amp again. But for my next move, should it be:SpectronExtreme HurricanesManley Neo Classic 250'sVTL 450'sor Ted's McCormack
Pete,Might be a little more than you wanted to spend, but there is a pair of Manley 500's on Agon that I bey would sound killer:http://cls.audiogon.com/cgi-bin/cls.pl?ampstube&1221048362George
What did you not like about the Pass?
Being that the HT3's are pretty inefficient I am not sure how tubes would work? I would say Ted's McCormack or the Spectron. You have the 36.5 in place so my suggestion would be solid state for the amplification.
Quote from: rydenfan on 21 Jul 2008, 01:54 amBeing that the HT3's are pretty inefficient I am not sure how tubes would work? I would say Ted's McCormack or the Spectron. You have the 36.5 in place so my suggestion would be solid state for the amplification.That is exactly the sticky point. For sure the Spectron has the kahones and the Manley may not at 250 of tube power.
VAC ?? I have never listened to it.. but I haven't heard anything negative about them.
Quote from: AliG on 22 Jul 2008, 12:18 amVAC ?? I have never listened to it.. but I haven't heard anything negative about them.Which one and do they come in 350 watts+ versions?
