0 Members and 1 Guest are viewing this topic. Read 24829 times.
I may consider using: Scott Nixon Tube DAC with USB (newest one when he releases it) Audio note kit 2.1, Hagerman Technology. Musical fidelity Xdac v8, Oritek Audio (when he designs with USB). Benchmark Dac 1 USB. Pacific Valve Brigatta, etc.
Quote from: Lizard_King on 7 Jun 2008, 04:51 pm I may consider using: Scott Nixon Tube DAC with USB (newest one when he releases it) Audio note kit 2.1, Hagerman Technology. Musical fidelity Xdac v8, Oritek Audio (when he designs with USB). Benchmark Dac 1 USB. Pacific Valve Brigatta, etc.I just got back my SN USBTD. It was upgraded to the constant current supply spec by Scott. I also have his better power supply. Sounds very nice and favors well to stuff I have now and from what I can remember owning. Its relaxed and musical with most music I’ve thrown at it. 320k MP3’s and Waves using Foobar, Winamp and iTunes on a WinXP laptop. I use an NAS to store data on. It has a nice soundstage, wide and airy. Not bright, not a big top-end extension but I like that. My iPod Touch is sharper with more upfront vocal, narrower soundstage, same depth but a less musical - still very nice. The Nixon excels in its bass and mid-bass. Its not a lean DAC, but its not thick, fat and tubby. Its got some warmth, weight and authority. I think bass is one its best characters, very nice vocals too. I think this DAC is VERY similar to a CAL Sigma-II I owned for some time. Compared to my Arcam FMJ? There isn’t any really, the FMJ does everything better. It’s considered a rich warm solid state CDP by most. The Nixon is warmer and not as extended. The Arcam has a VERY large soundstage in all directions and detail that’s extraordinary. I’ve tried a few tubes in the past and liked this early 80’s Yugo tube Scott sent me with it. He sent me a National Russian tube recently and I don’t like it as much. I have a PQ that wasn’t quite right in it a year or so ago; I haven’t tried it with the new circuit yet. I tried a classic Mullard but it gave off too much bloom. The guy I bought My Scott Nixon from when on to buy a Benchmark and the Bel Canto and wrote me months later saying he wanted the Nixon again, asked if I was happy with it. 0 Remember, the USB cable have literally NO effect on the audio, unlike SPDIF cables. USB DAC’s are the way to go.
Try the Musiland MD10 DAC. I am using it in a USB configuration but with a Squeezebox and am quite pleased with the sound. Its almost analog like.
Hello All,I am desiring to use my PC (Win XP) to drive my system. I already have a great Modified Denon player and I keep a lot of music on my PC in lossless format. The SPDIF on my M-Audio sound card does not cut it, even when I tried a buddy's Bel Canto Dac3.USB seems the way to go when you use a properly designed DAC with intelligent circuit topology. I will need to use a USB extender and then run 35-50 feet of Cat5 Ethernet cable. I am told this is good for up to 150 feet.There are many DACS out there that have USB, but few IMHO that handle the USB interface properly. Two DACS that IMHO can do it right are the Benchmark DAC1 USB and the Bel Canto Dac3 . I am hopeful to use another DAC and I am contemplating a tubed based one though it it not definite that I want tube. I must convey, I am NOT a DYI guy.Some designers like to convert from USB to SPDIF, others like to use USB and I2S and there are some who like to use Custom Software and drivers.I have dome some research and here are some that I may consider using: Scott Nixon Tube DAC with USB (newest one when he releases it) Audio note kit 2.1, Hagerman Technology. Musical fidelity Xdac v8, Oritek Audio (when he designs with USB). Benchmark Dac 1 USB. Pacific Valve Brigatta, etc.I really need your input and welcome to hear from anyone who has experience using this type of setup to please a fickle audiophile on a budget.Thanks in Advance and I hope to hear from you soon.
Look to the pro audio market for great quality, reasonably priced USB D/A, A/D, and S/PDIF interfaces. I have purchased many times from American Musical Supply (a.k.a. AMS). Here's their site:http://www.americanmusical.com/Search for "USB Audio Interfaces", or just start typing USB into the search box...Don't worry about all the hype. Just look at the specs. Oscillators are much better these days, even in the cheap USB stuff, and even the sloppiest audio companies just use the reference designs of the chips which are done well. Just look at the specs...
RWA... at $2500 this would have to be significantly better than anything else I'm looking at. No switchable inputs, probably multiple input options though.
