Please help with Red Dragon model 1 mini amps
0 Members and 1 Guest are viewing this topic. Read 2253 times.
DZetye
« on: 26 Feb 2008, 02:16 am »
Does anyone know what the input impedance is for the Red Dragon model 1 mini amps?  Or if its high or low from what a normal load is?  Thanks for any help you can provide.
Doug
Gaara
Re: Please help with Red Dragon model 1 mini amps
« Reply #1 on: 26 Feb 2008, 02:19 am »
A simple search brought me to this thread which says they have a 10k ohm input impedance.
DZetye
« Reply #2 on: 26 Feb 2008, 02:38 am »
Thanks Gaara for the information.  I didn't realize there were any specifications for this model posted.  Now I just need to know whether that is considered low compare to your average power amp?  The preamp I want to use does not like low impedance loads.
Anyone?
Gaara
« Reply #3 on: 26 Feb 2008, 02:48 am »
I would say it is a little on the low side.  Most amps seem to be closer to the 25k-30k range.  Off the top of my head the following amps I have used fall in that range:  Earthquake Cinenova Grande, Parasound Halo A23, Rotel RB-1070, PS Audio Trio, etc.
DZetye
« Reply #4 on: 26 Feb 2008, 02:51 am »
Thanks.  I will try them and hope a compatable union with the BAT preamp.  Supposedly the BAT does not work well with low impedance loads but what does Stereophile know, anyways.  Thanks for your help.
DZetye
« Reply #5 on: 26 Feb 2008, 02:58 am »
Since you took an interest I will let you know I found that the minimum input impedance of the amplifier according to BAT is 10k ohm, so I am at the absolute minimum with the Red Dragons.  Not exactly the compatability I was hoping for but I will try it never the less. Thanks again.
