0 Members and 1 Guest are viewing this topic. Read 20267 times.
Dan + Dale equals D-licious. Dan's Transporter tube analog stage (which also is the 24/96 DAC output) is incredible. Check out all of our comments on Dan's Circle. Add this to your Dale Pitcher-designed Intuitive Design Summits, a reference transducer, and you've got an incredibly simple and straightforward powerhouse of a system.
Will you need to play a CD too or are you always going to rip new music into the server? You will need a physical transport as well if you also want the option of playing direct from a disc.
Hmm, I'm considering the same things.How about a Cambridge Audio 840C (has a digital input) + Squeezebox Duet (when it comes out)?
Since neither squeezebox nor transporter has digital inputs, you will also need an external DAC (along with a transport) if you need to play a disc.
Quote from: woodsyi on 20 Feb 2008, 04:17 amSince neither squeezebox nor transporter has digital inputs, you will also need an external DAC (along with a transport) if you need to play a disc. ?? Not true at all. The Transporter has four digital inputs, and as a DAC it is wonderful (especially Modwright-ed).
Of course, there are mods available for any of these paths that will improve the sound.
The volume pot on the TP is clean, and unless attenuated substantially will not lop off significant bits.
not to confuse things but i am contemplating some of the same options. Another one to examine may be the empirical audio offerings, eg. pace car or freeway.I may jump in with a bolder modded squeezebox until this server things gets a bit mature...
One thing to bear in mind is that the Squeezebox/Transporter architecture is inherently superior to CD playback. There are no moving parts in these devices, and the data is received asynchronously over a computer network at much faster than playback speed, cached in a large buffer, and then clocked out at the DAC using a local oscillator. With that setup there is no opportunity for jitter to affect the sound at the DAC (except whatever is introduced on the board traces passing between the buffer and the DAC). With an external DAC, as always there will be jitter introduced by the S/PDIF connection, but the jitter at the SB output is low, and at the TP output it's SOTA.My SB3 is connected to a Benchmark DAC 1 which serves as a preamp (I've also got a universal disc player I use for movies connected to it). I'm very happy with both the sound and the convenience. As others have noted, the best thing about this architecture is the ease with which you can access your music - the result is I listen to much more music than I did before, and that's what matters the most.
We at AC can also try to organize a panel to describe the quality of sound from each configuration. This will obviously be a qualitative description with or without direct comparison but it will be interesting to read various different takes.
