0 Members and 1 Guest are viewing this topic. Read 20268 times.
By far the absolute best digital I've heard is Wayne at Bolder's latest uber mods on the SB3 and his MkIV power supply. Couple that to his modified Burson Buffer and I'm convinced it simply doesn't get any better at any price. Keep in mind, what sounds good in my reference system, my not work in yours.
hard drive space is cheap. You can have a TB of external storage for under $300 (if you watch where you shop). A TB of storage in raw WAV will easily get you somewhere around 600-800 CD's. After that, just add more storage.
Has anyone look at used this technology?:Exact Audio Copy: EAC is a free ripper like iTunes, except that it does multiple reads and corrects any errors and then outputs the signal through your computer's buffered memory. And how about the Nova Physics Memory player which is a fancier permutation of Exact Audio Copies perported technology?
As for dropping bits, the Slimserver s/w has a setting for lowering the preamp sensitivity, so you can keep the volume above 60 (of 100 steps) the place where supposedly you will experience bit loss if below.
Well, as I said I've checked several times whether my ripper (cdparanoia) reads the disc the same every time and it does (to the last bit). Maybe other people have had another experience but this is mine which I offer to you. So EAC and the Memory Player can be that good at reading discs too. But there's no room for them to be better (IME).Of course there may be other things about the Memory Player that make it sound superior...but I believe reading the data off the disc better than a ripper isn't one of them.Darren
I've never heard nor read a derogatory comment about the Nova Physics player's performance, but the price is the kicker for most. I'd love an opportunity to compare the MP, Dan Wright's Transporter and a completely modified Bolder SB in my system. One never knows, but I'd be surprised if the MP's performance would justify the price differential.
Quote from: Geardaddy on 21 Feb 2008, 11:48 pmHas anyone look at used this technology?:Exact Audio Copy: EAC is a free ripper like iTunes, except that it does multiple reads and corrects any errors and then outputs the signal through your computer's buffered memory. And how about the Nova Physics Memory player which is a fancier permutation of Exact Audio Copies perported technology?A great many here use EAC. I used it for about a year, up until mgalusha turned me on to Easy CD-DA Extractor. He and I (and probably others) performed bit-for-bit comparisons with files extracted via EAC and found they were exactly the same. It's much easier to use that EAC, rips CDs more quickly and was my program of choice until I moved to a Mac platform.I've never heard nor read a derogatory comment about the Nova Physics player's performance, but the price is the kicker for most. I'd love an opportunity to compare the MP, Dan Wright's Transporter and a completely modified Bolder SB in my system. One never knows, but I'd be surprised if the MP's performance would justify the price differential.
Quote from: mcgsxr on 21 Feb 2008, 11:52 pmAs for dropping bits, the Slimserver s/w has a setting for lowering the preamp sensitivity, so you can keep the volume above 60 (of 100 steps) the place where supposedly you will experience bit loss if below.Right. Please note however this setting still works with digital attenuation. If you want to match sensitivities using analogue you need to buy some in-line attenuators or use a power amp with variable input sensitivity (assuming the idea is to avoid a preamp).Regards, Darren
Quote from: Double Ugly on 22 Feb 2008, 12:48 amQuote from: Geardaddy on 21 Feb 2008, 11:48 pmHas anyone look at used this technology?:Exact Audio Copy: EAC is a free ripper like iTunes, except that it does multiple reads and corrects any errors and then outputs the signal through your computer's buffered memory. And how about the Nova Physics Memory player which is a fancier permutation of Exact Audio Copies perported technology?A great many here use EAC. I used it for about a year, up until mgalusha turned me on to Easy CD-DA Extractor. He and I (and probably others) performed bit-for-bit comparisons with files extracted via EAC and found they were exactly the same. It's much easier to use that EAC, rips CDs more quickly and was my program of choice until I moved to a Mac platform.I've never heard nor read a derogatory comment about the Nova Physics player's performance, but the price is the kicker for most. I'd love an opportunity to compare the MP, Dan Wright's Transporter and a completely modified Bolder SB in my system. One never knows, but I'd be surprised if the MP's performance would justify the price differential.what do you use now for your mac?
2. Mark's next step is to get rid of the data that have to do with the Reed-Solomon Error Correction Code (RS-ECC). ?? Is this relevant and if so, what if any shareware exists to make this correction?
Quote from: ted_b on 21 Feb 2008, 04:06 amI use volume pot as a general term; should have said volume control. Yes, of course it's not a potentiomter; it's digital. As far as reducing resolution (significant bits a play on words):http://forums.slimdevices.com/showthread.php?t=39611Well, perhaps I'm missing something, but I don't think you need to worry about bits at all:http://www.audiocircle.com/index.php?topic=51288.0
I know this isnt terribly scientific, but having the Wadia 170 iDock in for review, I played some wav files ripped to an iPod Nano, which is flash memory and a regular iPod with a hard disk.I used a Wadia 521 DAC for one test and the DAC section of my Meridian 808i for the other, and the third on the Benchmark DAC-1 USBIn all three instances, it seemed like the files played back from the Nano sounded a bit more natural. Again, not scientific, but when I had a couple of non audiophile friends over to listen, they all picked the nano every time, so maybe those memory player guys are on to something!!
Last May, we made the move to a computer based system:Mac Mini Airport Express ExtremeWD 500GB external drives(2)Squeezebox 3 (2)Since then, we have added another 2 750GB WD external drives. The main drives are attached to the Airport Express Extreme unit. The Squeezeboxes are driven wirelessly.We use Itunes to load music (lossless of course). I use CoverScout to find cover art and update it for use by Slimserver. CoverScout is fair - can cause problems. We have auto-backup running every week. The backup drives are connected to the Mac Mini.I haven't played a disk on my Audiomeca transport in 8 months and it is not even plugged in today.For our main system, we use the SB3 digital output into an Audiomeca Dac and it is truly good sound. For our second system, we use a SB3 direct. It is OK.I control everything via the Slimserver web interface and that is OK, not the best. I am hoping to get an eee laptop soon for use as a dedicated remote. I can also control stuff from my Phillips Pronto, but it is hard for my old eyes to see the display on the Squeezebox units.I can say that this is the best thing to happen to our music since I bought my first pair of Dunlavy IVs 15 years ago! I have discouvered just how good my music collection is and we listen to all kinds of stuff that stayed in the CD drawers before. It is just so easy to hear anything you wish any time you wish - PLUS - Random play is like a weird soundtrack to your life and often loads tunes that haven't been played in years. I have also created "playlists" that replicate all my mix disks and now can generate a party mix for a week long blow out (as if my old head could last that long...).I believe the Macs are a great way to get started - also can be used to store movies and other stuff if you are inclined. If I had it to do over or had a few extra bucks to spend, I would definitely get a Modwright transporter. I think it would be the very best sound you will ever need!
