0 Members and 1 Guest are viewing this topic. Read 8775 times.
There are a few power cond. that are affective in cleaning the AC. Very affective as a matter of fact. IMO though they all seem to have a house sound. I would think that if your components have a filtering system in their power supply this is redundant and possibly harmful in the long run. When you delve into the equip with a well designed power supply say Macintosh, CJ, Audio Research the need for such devices becomes moot. First IMO the basic electric. service is what requires attention. The panel, breakers and yes wire are critical to clean power. Especially the grounding scheme. A copper that reaches the water table below is critical. Just run a dedicated line in conduit for each component. Use Industrial duplex outlets and non ferrous wall plates. A dedicated sub panel from your main panel would be recommended. Romex is great for power wiring, especially the Cryo treated stuff. To date not one PC or BPC have improved the sound. I admit I have yet to try the RSA line so I cannot pass judgment. If these devices improve the quality of power without going through the above I'm in. One last thing. The only device that benefited from conditioning was the CDP. Go figure.spud
There is no way a piece of gear could make an RSA or anyone elses power conditioner sound bright.Physics doesn't work that way....
.......There is no way a piece of gear could make an RSA or anyone else's power conditioner sound bright.Physics doesn't work that way....
