0 Members and 1 Guest are viewing this topic. Read 7748 times.
Hey Ricardo,I have a complete Shigaraki (on the CD side) based system with Omega Super 3XRS/hemps but my room looks very different from yours.Your listening preferences sound like you could be thrilled by the strengths of this combo (guitar and voice a nearfierld listening is just insanely good) but I also have to say that it is a very revealing one.For me, it makes almost all rock and thinly recorded music difficult to enjoy.Again, I am basing this on Shigaraki CD/DAC/amp/OTA cable, cannot really comment on other op or tube amps from experience.Check out this post from Ikakenewa, it exactly sums up my findings (although Boston was never my cuppa tee):http://www.audiocircle.com/index.php?topic=35524.70If single drivers are up your alley (they still are up mine), it's worth looking into Louis' creations since they are well designed and exceptionally beautiful...Maxhemp, Superhemp... Plus he is a kool guy.
Don't forget about the Hemp Bi/Dipoles. They might require a greater distance from the back wall but 3 feet might be OK. Presently I'm using my Hemp Omegas in the dipole mod and biamping them with Trends 10.1 amps and employing a Mapletree line 3A SE tube preamp. I also have an ACI Titan sub to fill in the bottom but Louis's new sub is tempting me . This setup provides simply stunning detail retrieval and separation. You get the added displacement of dual 4 1/2" drivers to provide body and ambiance while retaining the awesome speed of the little hemps. Biamping is a natural since you have essentially 4 separate speaker enclosures contained within two cabinets with four sets of connectors.
4. Does the SUB have to be positioned in the middle between the speakers? If so, I can't have one. It's also not in line with the minimal approach of my 47 system...
Dipole is the typical plannar phenom. Think of mounting a single cone in an open baffle. It pushes air forward out the front while pulling air forward from the back. The larger waveforms from lower frequencies cancel in the plane of the baffle. Provides a large diffuse soundstage. These don't provide pin-point imaging, more like what you'd experience at live performance. Louis uses two matching drivers in ported cabinets.Bipole is similar but opposite. It uses two drivers, but both push out at the same time so that the lower frequencies don't cancel as with the dipoles.With two matching drivers per channel you can also vary the impedance (cutting in half or doubling) depending on how you connect them.
Quote from: tuga on 2 Sep 2007, 09:12 am4. Does the SUB have to be positioned in the middle between the speakers? If so, I can't have one. It's also not in line with the minimal approach of my 47 system... http://www.sakurasystems.com/show/kai.htmlIf you want to go even simpler (no rack and the Shigarakis on the floor) then a sub will indeed be difficult.
The 4.5" driver in the Super 3 / XRS is a hemp driver.Louis built his new Subwoofer the same dimensions (depth and width) as the compact hemp, so you could use the Subs as stands for the CH with some sort of decoupling device in between.
Actually I find the imaging with the Omega Dipoles to be very good. I can place the instruments in a symphony orchestra or jazz group with no problem.
In the new cubic room you could fill the room with anything from 5 inch to 8 inch drivers. I listen nearfield (1.7 meter equalateral triange between speakers and me) in a room of about the same volume to 8 inch drivers at normally moderate levels to mostly small ensemble classic, jazz, and pop. But with the concerns for standing waves I'd shy away from lots of bass.
Most of us aren't in Europe, so we aren't overflowing with ideas that wouldn't involving import fees or major shipping. Lowthers (the grand daddy of extended range drivers), Fertin (field coils, supposed to be good but know little about them), Supervox (again don't know much about them), and the 9 inch Visaton B200 extended range driver (some would call a mid/tweeter) all about all the European extended range drivers I can think of. The rest come from the Far East. A very intriguing Japanese driver that would fit into the 47 scheme is the Feastrex:
Quote from: DaveC113 on 2 Sep 2007, 01:29 pmThe 4.5" driver in the Super 3 / XRS is a hemp driver.Louis built his new Subwoofer the same dimensions (depth and width) as the compact hemp, so you could use the Subs as stands for the CH with some sort of decoupling device in between. How much does the subwoofer unit cost?Super 3 XRSs cost around 1650 USD in Europe...If shipping were cheap I might order them directly as I have to pay 27% TAX on top of goods+shipping cost = 950+100+tax = 1390 USD
There is also the possibility of Louis later coming out with a Super 3 Hemp XRS Dipole, with the 8" DeepHemp Sub driver built into a sealed chamber on the bottom of the cabinet!
