0 Members and 1 Guest are viewing this topic. Read 16833 times.
I'm trying to get them to talk to each other. Is it necessary I have a router? Or can I simply link the two via the Cat6 or a USB cable? I have no intention of both of them being on line at the same time. When all is said and done, the HT rig won't ever be on the net unless it's finding music tags.
since both machines can use your broadband connection at once,
Option "A" seems unnecessary and costly,
Option "B" seems slightly unnecessary and costly, maybe.
Option "C" sounds interesting. I don't know what a 'crossover' cable is. Looks like something I need to Google in the AM. But this option appears to be inexpensive.
I thought this project was going to (relatively) as simple as the Cat6 from PC to XBox360. It was (almost) as simple as plugging both ends and answering a few questions.
Good information about the USB cables having different ends. I've wondered that. Never seen equivalent ends on one cable before but I've never looked for it either. It seems based on your description that I could call one of the PC's 'the host' and the other 'a device'......But then I'd still be left with needing a cable with the proper ends.???
When you say USB needs a device in the middle, A cheap hub from Walmart is all I'd need?? Then PC #2 could plug in and be considered 'a device'.
Since I'd be needing a cable run of about 25' when I get things where I want them, is the Cat cable a better idea than USB?
A crossover cable just swaps the transmit/receive wires so you can have two computers talk to each other without a hub or switch between them. This would cost you less than $10. Of course, many modern PC ethernet adapters are autosensing and will automatically do the swap for you, so try a regular cable first. If you do need a crossover cable, here's one at Staples for $7.50:http://www.staples.com/webapp/wcs/stores/servlet/StaplesProductDisplay?langId=-1&storeId=10001&prodCatType=1&catalogId=10051&productId=151432&cmArea=SC3:CG58:DP1426:CL140456
Quote from: Rashiki on 25 Aug 2007, 05:11 amA crossover cable just swaps the transmit/receive wires so you can have two computers talk to each other without a hub or switch between them. This would cost you less than $10. Of course, many modern PC ethernet adapters are autosensing and will automatically do the swap for you, so try a regular cable first. If you do need a crossover cable, here's one at Staples for $7.50:http://www.staples.com/webapp/wcs/stores/servlet/StaplesProductDisplay?langId=-1&storeId=10001&prodCatType=1&catalogId=10051&productId=151432&cmArea=SC3:CG58:DP1426:CL140456But, technically is a crossover cable any different that any other cable with ethernet sized jacks (RJ45) on it?Isn't what I have a crossover cable? (looks like Cat wire with RJ45 plugs on both ends)
