0 Members and 1 Guest are viewing this topic. Read 16847 times.
I'll see if I can hack into my Dell account (it's been a while),
I assume you've enabled PPoE?
Well, I'm not a network engineer - but I did sleep at a Holiday Inn last night
I've honestly not ever set up one quite like this before.
By the way, I meant to ask;It seems apparent to me that the type of cable I'm using may be vital. Back on page one it was mentioned that a crossover cable has the same jacks/terminations as a standard ethernet cable and will physically interchange.Could I inadvertantly be using the wrong cable? Do I check by testing for continuity from 'pins' "A" to "A", and "B" to "B" etc.... My thinking is that the crossover cable would NOT have continuity on equal pins.....I shouldn't be using crossover cables with this router, right?
