Bryston CD Player Literature
0 Members and 1 Guest are viewing this topic. Read 8956 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 6 Jun 2007, 10:33 am »
Hi All,
Here is the preliminary literature on the Bryston CD Player and the Owners Manual.
http://www.bryston.ca/pdfs/07/BCD-1CD.pdf
http://www.bryston.ca/BrystonSite05/pdfs/manuals/BCD1_MANUAL_20070605.pdf
james
BachToRock
Re: Bryston CD Player Literature
« Reply #1 on: 6 Jun 2007, 05:15 pm »
Outstanding James... looks great!
Two questions... does the code for the BP26 also work for the BP25?  Also, are the analog outs variable?  The manual does not specify that the VOLUME control on the remote is exclusive to outside compatible components...
b5pt9
« Reply #2 on: 6 Jun 2007, 05:23 pm »
And does it come in black as well as silver?
budt
« Reply #3 on: 6 Jun 2007, 05:28 pm »
  What is the canadian msrp ?
« Reply #4 on: 6 Jun 2007, 05:31 pm »
HI,
1. Yes the CD remote will work with the BP25
2. The analog outs are not variable at the moment but we can do that in the future if we wish (software upgrade)
3. The CD Remote will only work with other Bryston components.
james
« Reply #5 on: 6 Jun 2007, 05:32 pm »
Yes Black or Silver - 17 inch or 19 inch C-Series
« Reply #6 on: 6 Jun 2007, 05:33 pm »
$2695
james
BachToRock
« Reply #7 on: 6 Jun 2007, 10:01 pm »
If the analog outs are variable via the digital domain wouldn't there be resolution loss as you reduce from full output?
The variable outs would make it a sure-fire piece for myself if there is no fidelity comprimise... I requested that long ago here when you were inquiring our input...
« Reply #8 on: 6 Jun 2007, 10:12 pm »
Yes digital variable outputs always have a resolution loss - that is why we are looking into it further before we decide how to overcome the compromise.
james
Hoiman
« Reply #9 on: 8 Jun 2007, 06:15 am »
What gives a better sound? CD play through analog out or let the SP2 do the DA conversion?
Levi
« Reply #10 on: 8 Jun 2007, 11:26 am »
The CD Player has a good internal D to A converter.  It is imperative to say that the CD Player will sound good when used as stand-alone player.
Front
Back
« Reply #11 on: 8 Jun 2007, 11:35 am »
Hi Hoiman,
Have a look at the literature on the CD Player on our website. There is a section on the first page called ADVANTAGE. I think it will go a long way to answering your question.
james
« Last Edit: 8 Jun 2007, 11:51 am by James Tanner »
rob80b
« Reply #12 on: 8 Jun 2007, 01:50 pm »
In terms of sound quality I guess we’ll know soon enough as we start weeding through the subjective and objective reviews. But as a pro Bryston fan I’m sure they have done their homework, I’m planning to pick one up to replace my aging but venerable workhorse a Teac VRDS-20.
Also, James are there pics of the inners available for those curious few who like to take a peek of the under the hood?
« Reply #13 on: 8 Jun 2007, 01:55 pm »
Hi Rob,
The 'innards' are being photographed this weekend so I should have some next week for you.
james
Levi
« Reply #14 on: 8 Jun 2007, 03:24 pm »
I have an unofficial picture but I rather wait for James.
« Reply #15 on: 8 Jun 2007, 03:31 pm »
Yes the unofficial picture was a very early engineering prototype.
james
Bob Reynolds
« Reply #16 on: 8 Jun 2007, 04:44 pm »
Hi All,
james
James,
Will a block diagram be available? I assume it uses an async sample rate converter; I'm interested in how that is being clocked.
« Reply #17 on: 8 Jun 2007, 04:47 pm »
Hi All,
james
James,
Not sure I will check with engineering.
james
« Reply #18 on: 8 Jun 2007, 05:18 pm »
Hi All,
james
James,
james
James,
This one is easy.
The BCD1 does not use a sample rate converter.
Dan
Engineering
lossless
« Reply #19 on: 8 Jun 2007, 06:19 pm »
Hi Hoiman,
james
if jitter is the case with using an external dac, then why even bother having all of those digital outputs on your player??  it just adds to the costs, does it not?
« Last Edit: 8 Jun 2007, 06:35 pm by lossless »
