0 Members and 1 Guest are viewing this topic. Read 12961 times.
The only power conditioning I have ever seen incorporated into a component itself is in my preamp (Audio Prism Mantissa) and the tube amp driving my tweeters (Audio Prism Debut II). Audio Prism incorporated its Quiet Line filters right into the power supply components on each. I guess it makes sense, since this is one of their corporate goldpieces and if it doesn't work well for them then ...I would expect that PS Audio would do the same in their components, but maybe not.Enjoy,Bob
Are you referring to Y filters as in IEC Corcoms or are you also speaking about voltage regulation and ripple rejection?
...I have also not really noted much of any consumer demand for manufacturers to put "power conditioning" inside the units that are purchased. This lack of demand for this does have me a bit puzzled...What I would like to know is what are your expectations of the equipment you purchase and why as it applies to this subject...
Answering the original question:Surge protection/voltage regulation are the only meaningful features in a power conditioner. And it is not for some sound improvement non sense but for equipment protection.
Dan,I'm a bit confused/thick. To take care of the hash, you are suggesting something exterior to the equipment, correct? So the equipment manufacturer needn't worry about it. Or are you proposing handling it externally and internally?Phil
Quote from: Phil on 5 Jan 2007, 06:41 pmDan,I'm a bit confused/thick. To take care of the hash, you are suggesting something exterior to the equipment, correct? So the equipment manufacturer needn't worry about it. Or are you proposing handling it externally and internally?PhilThere's a couple ways of looking at it, you want to keep hash & noise out of the equipment and you don't want the equipment to generate its own hash & noise either. For example, you don't want the noise from a dimmer switch or crappy computer power supplies getting into the audio gear through the power lines. On top of that, let's say you're using directly heated triodes such as a 300B, you don't want to run the filaments of the 300B with a noisy switchmode power supply since that'll dump a ton of hash right into the tube itself, that's an example of internal noise.So to answer the question, noise & hash has to be handled both inside & out, it doesn't make sense to feed the equipment perfect AC when it's its own noise machine. Going the other way, you don't want to feed your gear dirty power even if it could filter out nearly everything, because the key word is "nearly". The noise can still get into the circuit by coupling through the enclosure and the air, it is in most cases prohibitively hard and expensive to get rid of.In short, feed the gear clean power and design the gear so it doesn't create too much noise of its own.
Aerius,Thanks. Very sensible and well stated. It seems to me that tracking down where ALL the noise is coming from is difficult for the average audiophile. For example, it was very clear that running my gear on a shared circuit with a light dimmer and a ceiling fan was adding noise. Turn off the light and/or the fan and the noise went away. A dedicated circuit cured that problem. But, even a dedicated line carries noise it seems. So I added a balance power unit for the source only. The amp was plugged into the shared outlet. That worked even better.Out of curiosity, I added another dedicated circuit (much less expensive than upgrading a power cord). Separating digital and analog made a big difference. This change has me puzzled though. I assumed that the balance power gear was not only filtering the noise coming into the digital source, but also any noise that might be created by the source and introduced into the amp via the shared dedicated outlet. Why do you think this worked as well as it did (not complaining, but curious about the reason). And for those who don't believe in this stuff and think it is all in my head, that is fine with me since my ears are connected to my head. Phil
...Some Audiophiles don't seem to like the Tripplite Isobar, and Hi End Audiophile dealers truly despise them. I've been using them for over 15 years both at home and on the job. You can get Isobar Ultra 8 for under 50.00 from www.provantage.com...
