0 Members and 1 Guest are viewing this topic. Read 31265 times.
Mini Max Pre output impedance 100k Ohm
The EE BBA specs are 800R to 10k output and the EE Minimax pre is 1.5K according to the morningstar audio site.
A BIG Thank You to John Cook of Back Sand Cable as he has graciously offered to send a couple of his Silver MKV powercords along with a couple of his Chromium powercords for me to try out after I contacted him through email. After Wayne had mentioned that the BBA benefits from a better powercord, I started searching and ran across the thread here at AC on the Black Sand powercords. Can't wait to try these.
It IS frustrating to think every time you add a device in the chain with an AC socket, you need $500+ worth of AC cord to get the most out of it
Oh .much more than that.. you also need a dedicated line for each component, then a power conditioner for each component....and then you need to try as many interconnects as possible to find the best match....so it's not all that simple..
