0 Members and 1 Guest are viewing this topic. Read 179912 times.
F-100,That should work right fine. If you wanted to save some room and a buck or two, you could easily drop the rated voltage of the caps to either 600v, 400v or 250v (I'm not sure what voltages and values are offered in the Mundorfs).
Scott, Does your your Paradisea have any of these mods yet? Since you cleared me on Bryan's Korato, I'm starting to feel dangerous again. aaAlan
I'm going to replace the output caps with Mundorf Silver 1.5uF/1200VDC and then bypassed them with Mundorf Silver 0.1µF/1200VDC.Is this good, bad or overkilled? Any feedback is appreciated. Thanks
I have done the OPA2107 opamp mod, the sound is more detail but also a lot more forward, I don't want to pass final judgement yet, I am going to bypass the power supply next. Tony, what are your impressions?
Anyone know the ouput voltage of the DAC and its compatibility with passive pre's?
My Paradisea had an on/off switch on the front like the one in this photo.
