0 Members and 1 Guest are viewing this topic. Read 10195 times.
That sounds like an intelligently built system. Congrats!If those drivers are typical of the breed, you have another couple of months of improvements in store too.I'd be careful with the varnish. I've heard many folks report improvements with it, but it does change the sound and is not reversible. If you choose to apply it, read up first. I think it has to be mixed with something else to thin it down for application and how much thinner is used relates to varnish thickness and degree of sound change. Go very light at first - multiple coats would be better than overshooting the mark the first time.If the drivers aren't too expensive, you could burn in a second set in the garage. Leave one set unvarnished and experiment with the other. Then you could even put one of each in a cabinet, put them side-by-side, and switch back and forth so you don't have to rely on the notably unreliable aural memory. Fun!
